Старый 26.06.2007, 16:32   #3
Delfins is offline
Delfins
Да, но я просто открываю акзапту, ничего не делаю, сразу закрываю и получаю крэш.
Вот стэк от запуска до закрытия
AXXppMethodBegin,       info, 0x0570,   128273347521565496,       4845,      13770,       16, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "new",        2, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521565710,       4845,      13770,       17, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "new",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521565905,       4845,      13770,       18, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "isServer",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521566135,       4845,      13770,       19, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "new",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521566265,       4845,      13770,       20, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "new",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521566375,       4845,      13770,       21, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "clientKind",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521566520,       4845,      13770,       22, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "clientKind",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521566730,       4845,      13770,       23, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "isServer",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521566850,       4845,      13770,       24, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyBegin",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521567034,       4845,      13770,       25, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "numberSeqGlobal",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521567243,       4845,      13770,       26, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "numberSeqGlobal",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521567312,       4845,      13770,       27, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "ttsNotifyBegin",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521567495,       4845,      13770,       28, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "runAutoClean",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521567860,       4845,      13770,       29, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "runAutoClean",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521567964,       4845,      13770,       30, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "ttsNotifyBegin",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521568061,       4845,      13770,       31, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyBegin",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521572688,       4845,      13770,       32, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyPostBegin",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521572940,       4845,      13770,       33, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "xApplication", "ttsNotifyPostBegin",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521573064,       4845,      13770,       34, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "xApplication", "ttsNotifyPostBegin",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521573138,       4845,      13770,       35, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "inventUpdateOnhandGlobal",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521573353,       4845,      13770,       36, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "inventUpdateOnhandGlobal",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521573426,       4845,      13770,       37, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "InventUpdateOnhandGlobal", "ttsNotifyPostBegin",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521573618,       4845,      13770,       38, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Map", "getEnumerator",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521574197,       4845,      13770,       39, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Map", "getEnumerator",        4, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521574317,       4845,      13770,       40, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Set", "new",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521574460,       4845,      13770,       41, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Set", "new",        4, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521574615,       4845,      13770,       42, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "MapEnumerator", "moveNext",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521574723,       4845,      13770,       43, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "MapEnumerator", "moveNext",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521574846,       4845,      13770,       44, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "InventUpdateOnhandGlobal", "ttsNotifyPostBegin",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521574943,       4845,      13770,       45, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyPostBegin",        2, 0, 0
AXXppUtilFunc,       info, 0x0570,   128273347521575172,       4845,      13770,       46, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "curusrid",             3322, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521575240,       4845,      13770,       47, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "loginDate",        2, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521575369,       4845,      13770,       48, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "loginDate",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521575442,       4845,      13770,       49, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "loginTime",        2, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521575554,       4845,      13770,       50, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "loginTime",        2, 0, 0
AXXppUtilFunc,       info, 0x0570,   128273347521575741,       4845,      13770,       51, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "convertUTCDateToLocalDate",            35760, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521575806,       4845,      13770,       52, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "loginTime",        2, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521575916,       4845,      13770,       53, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Session", "loginTime",        2, 0, 0
AXXppUtilFunc,       info, 0x0570,   128273347521576058,       4845,      13770,       54, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "convertUTCTimeToLocalTime",            23242, 0, 0
AXXppUtilFunc,       info, 0x0570,   128273347521584173,       4845,      13770,       55, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "today",            20685, 0, 0
AXXppUtilFunc,       info, 0x0570,   128273347521584320,       4845,      13770,       56, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "timenow",             7830, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521584481,       4845,      13770,       57, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "SysUserLog", "update",        2, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521590095,       4845,      13770,       58, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "SysUserLog", "update",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521590256,       4845,      13770,       59, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyPreCommit",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521590549,       4845,      13770,       60, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "xApplication", "ttsNotifyPreCommit",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521590654,       4845,      13770,       61, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "xApplication", "ttsNotifyPreCommit",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521590726,       4845,      13770,       62, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "inventUpdateOnhandGlobal",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521590943,       4845,      13770,       63, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "inventUpdateOnhandGlobal",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521591007,       4845,      13770,       64, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "InventUpdateOnhandGlobal", "ttsNotifyPreCommit",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521591205,       4845,      13770,       65, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Set", "getEnumerator",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521591349,       4845,      13770,       66, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Set", "getEnumerator",        4, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521591436,       4845,      13770,       67, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "SetEnumerator", "moveNext",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521591539,       4845,      13770,       68, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "SetEnumerator", "moveNext",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521591667,       4845,      13770,       69, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "InventUpdateOnhandGlobal", "ttsNotifyPreCommit",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521591766,       4845,      13770,       70, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyPreCommit",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521603236,       4845,      13770,       71, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyCommit",        2, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521603469,       4845,      13770,       72, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "numberSeqGlobal",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521603687,       4845,      13770,       73, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "numberSeqGlobal",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521603764,       4845,      13770,       74, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "ttsNotifyCommit",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521603944,       4845,      13770,       75, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "runAutoClean",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521604309,       4845,      13770,       76, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "runAutoClean",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521604410,       4845,      13770,       77, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "NumberSeqGlobal", "ttsNotifyCommit",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521604492,       4845,      13770,       78, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "TransactionlogUpdateTTSControl", "ttsNotifyCommit",        3, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521604667,       4845,      13770,       79, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "TransactionlogUpdateTTSControl", "isInvoked",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521604888,       4845,      13770,       80, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "TransactionlogUpdateTTSControl", "isInvoked",        4, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521604988,       4845,      13770,       81, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "TransactionlogUpdateTTSControl", "ttsNotifyCommit",        3, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521605087,       4845,      13770,       82, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "ttsNotifyCommit",        2, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521605290,       4845,      13770,       83, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "closingDown",        1, 0, 0
    AXRPCEnd,       info, 0x0570,   128273347521605440,       4845,      13770,       84, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "ServerEvalFunc",        1,        0,       48, 0, 0
  AXRPCBegin,       info, 0x0570,   128273347521664333,       4845,      13770,       85, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "ServerLastValueSave",        1,      539,        0, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521704089,       4845,      13770,       86, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "SysLastValue", "Update",        1, 0, 0
AXXppMethodEnd,       info, 0x0570,   128273347521726862,       4845,      13770,       87, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "SysLastValue", "Update",        1, 0, 0
    AXRPCEnd,       info, 0x0570,   128273347521738544,       4845,      13770,       88, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "ServerLastValueSave",        1,        0,        0, 0, 0
  AXRPCBegin,       info, 0x0570,   128273347521744645,       4845,      13770,       89, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "ServerLoadFlushInfo",        1,        2,        0, 0, 0
    AXRPCEnd,       info, 0x0570,   128273347521755534,       4845,      13770,       90, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "ServerLoadFlushInfo",        1,        0,      296, 0, 0
  AXRPCBegin,       info, 0x0570,   128273347521784073,       4845,      13770,       91, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "ServerEvalFunc",        1,       81,        0, 0, 0
AXXppMethodBegin,       info, 0x0570,   128273347521784181,       4845,      13770,       92, "AOS_AOSSERVER_2717", "XYZ",      5,        0, "Application", "closingDown",        1, 0, 0
Последний раз редактировалось Delfins; 26.06.2007 в 16:42.
вылетает аксапта \Classes\CCMenuButtonAuto\new Poleax DAX: Программирование 10 12.02.2009 18:24
Вылетает пакет sergeypp DAX: Администрирование 5 24.12.2007 15:05
Ошибка: Сессия работы на сервере AOS прервана... Atani DAX: Программирование 6 09.08.2007 09:28
Использование профилировщика и толкование результатов его работы belugin DAX: Программирование 3 22.11.2005 16:56
Организация работы программистов Андре DAX: Прочие вопросы 34 29.05.2002 13:16
Часовой пояс GMT +3, время: 01:50.
