Старый 15.04.2008, 20:05   #1
25,643 / 848 (80) +++++++
dax-lessons: Create HTML using HtmlTextWriter class in x++
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!143.entry
HtmlTextWriter class is used to output properly formed HTML into a web page. The HtmlTextWriter allows the developer to code attributes, style attributes, and tags etc.
The HtmlTextWriter class permits the developer to generate page output in a non-browser specific way; that is to say, the burden of developing alternative markup is typically removed by using the HtmlTextWriter. The HtmlTextWriter class exposes properties, fields, and methods that permit the developer to format HTML 4.0 compliant output.
For example, in the job below i added static string and an image using the HtmlTextWriter class.
static void HTMLTextWriter(Args _args)
    HTMLTextWriter htw = new HTMLTextWriter();
    TextBuffer     txtBuffer = new TextBuffer();
    CCHTMLString   staticString;
    staticString = @'At Solugenix we know our success results from taking a long term view in all
    our relationships: clients, employees, industries and technologies.';
    htw.renderBeginTag(HtmlTextWriterTag::table());
    htw.renderBeginTag(HtmlTextWriterTag::tr());
    htw.write(staticString);
    htw.addAttribute(HtmlTextWriterAttribute::class_Attribute(), 'ms-vb');
    htw.addStyleAttribute(HtmlTextWriterStyle::width(), '26px');
    htw.addStyleAttribute(HtmlTextWriterStyle::padding_top(), '3px');
    htw.renderBeginTag(HtmlTextWriterTag::td());
    htw.addAttribute(HtmlTextWriterAttribute::src(), 'http://www.holidayegreetingssite.com/index_files/image3121.jpg');//get the image from web
    htw.addStyleAttribute(HtmlTextWriterStyle::width(), '100');
    htw.addStyleAttribute(HtmlTextWriterStyle::height(), '50');
    htw.renderBeginTag(HtmlTextWriterTag::img(), true);
    htw.renderEndTag(); //close
    txtBuffer.setText(htw.getHtmlString());
    txtBuffer.toFile('f:\DynamicsAX.html');  // please provide your path to save the file
The result of the above code will be -
dax-lessons: Create Outlook Appointment or Meeting Request using X++ Blog bot DAX Blogs 0 30.04.2008 23:07
dax-lessons: Create Technical Document from AX Blog bot DAX Blogs 0 12.03.2008 09:05
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 19:17.
