#1 |
#2 |
конечно, вот план с cyrillic (заменил квадратные скобки на фигурные и заменил кое-где двоеточия на дефисы, т.к. иначе форум не дает отправить сообщение - говорит слишком много картинок)
|--Stream Aggregate(GROUP BY-({A}.{ITEMID}))
|--Nested Loops(Inner Join, OUTER REFERENCES-({B}.{INVENTDIMID}, {Expr1007}) WITH ORDERED PREFETCH) |--Nested Loops(Inner Join, OUTER REFERENCES-({A}.{ITEMID}, {Expr1006}) WITH ORDERED PREFETCH) | |--Clustered Index Seek(OBJECT-({db_cyr}.{dbo}.{INVENTTABLE}.{I_175ITEMIDX} AS {A}), SEEK-({A}.{DATAAREAID}={@0}), WHERE-({db_cyr}.{dbo}.{INVENTTABLE}.{A_LINECODE} as {A}.{A_LINECODE}={@1}) ORDERED FORWARD) | |--Clustered Index Seek(OBJECT-({db_cyr}.{dbo}.{INVENTSUM}.{I_174ITEMDIMIDX} AS {B}), SEEK-({B}.{DATAAREAID}={@2} AND {B}.{ITEMID}={db_cyr}.{dbo}.{INVENTTABLE}.{ITEMID} as {A}.{ITEMID}), WHERE-({db_cyr}.{dbo}.{INVENTSUM}.{CLOSED} as {B}.{CLOSED}={@3} AND {db_cyr}.{dbo}.{INVENTSUM}.{CLOSEDQTY} as {B}.{CLOSEDQTY}={@4}) ORDERED FORWARD) |--Clustered Index Seek(OBJECT-({db_cyr}.{dbo}.{INVENTDIM}.{I_698DIMIDIDX} AS {C}), SEEK-({C}.{DATAAREAID}={@5} AND {C}.{INVENTDIMID}={db_cyr}.{dbo}.{INVENTSUM}.{INVENTDIMID} as {B}.{INVENTDIMID}), WHERE-({db_cyr}.{dbo}.{INVENTDIM}.{INVENTPROJECTID} as {C}.{INVENTPROJECTID}={@6}) ORDERED FORWARD) Цитата:
|--Compute Scalar(DEFINE-({Expr1006}=tertiary_weights({db_1251}.{dbo}.{INVENTTABLE}.{ITEMID} as {A}.{ITEMID})))
|--Stream Aggregate(GROUP BY-({A}.{ITEMID})) |--Nested Loops(Inner Join, OUTER REFERENCES-({B}.{INVENTDIMID}, {Expr1008}) WITH ORDERED PREFETCH) |--Nested Loops(Inner Join, OUTER REFERENCES-({A}.{ITEMID}, {Expr1007}) WITH ORDERED PREFETCH) | |--Clustered Index Seek(OBJECT-({db_1251}.{dbo}.{INVENTTABLE}.{I_175ITEMIDX} AS {A}), SEEK-({A}.{DATAAREAID}={@0}), WHERE-({db_1251}.{dbo}.{INVENTTABLE}.{A_LINECODE} as {A}.{A_LINECODE}={@1}) ORDERED FORWARD) | |--Clustered Index Seek(OBJECT-({db_1251}.{dbo}.{INVENTSUM}.{I_174ITEMDIMIDX} AS {B}), SEEK-({B}.{DATAAREAID}={@2} AND {B}.{ITEMID}={db_1251}.{dbo}.{INVENTTABLE}.{ITEMID} as {A}.{ITEMID}), WHERE-({db_1251}.{dbo}.{INVENTSUM}.{CLOSED} as {B}.{CLOSED}={@3} AND {db_1251}.{dbo}.{INVENTSUM}.{CLOSEDQTY} as {B}.{CLOSEDQTY}={@4}) ORDERED FORWARD) |--Clustered Index Seek(OBJECT-({db_1251}.{dbo}.{INVENTDIM}.{I_698DIMIDIDX} AS {C}), SEEK-({C}.{DATAAREAID}={@5} AND {C}.{INVENTDIMID}={db_1251}.{dbo}.{INVENTSUM}.{INVENTDIMID} as {B}.{INVENTDIMID}), WHERE-({db_1251}.{dbo}.{INVENTDIM}.{INVENTPROJECTID} as {C}.{INVENTPROJECTID}={@6}) ORDERED FORWARD) Время выполнения определял двумя способами либо селектами вида Цитата:
declare @d datetime
set @d =getdate() select ... from ... select db_name(),getdate(), @d, datediff(ms,@d,getdate()) либо включением SET STATISTICS TIME ON (давала почти идентичные результаты, что и select db_name(),getdate(), @d, datediff(ms,@d,getdate()) PPS: я тоже был уверен, что скорость должна возрасти, особенно когда первая проверка показала рост скорости в 1000 раз, но вот усредненная реальность подставила подножку... Да и сейчас надеюсь еще найти "волшебный переключатель" Последний раз редактировалось VitaliyK; 20.09.2007 в 13:49. |
#3 |
вот еще планы из примеров выше
~300ms Цитата:
select
* from SalesPickingListJournalLine isum (nolock) where PickingListId like '%01Н0002320%' select db_name(),getdate(), @d, datediff(ms,@d,getdate()) go Цитата:
|--Parallelism(Gather Streams)
|--Nested Loops(Inner Join, OUTER REFERENCES-([Bmk1000])) |--Index Scan(OBJECT-([db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE].[I_806DELIVERYREQUESTIDX] AS [isum]), WHERE-([db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE].[PICKINGLISTID] as [isum].[PICKINGLISTID] like '%01Н0002320%')) |--RID Lookup(OBJECT-([db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE] AS [isum]), SEEK-([Bmk1000]=[Bmk1000]) LOOKUP ORDERED FORWARD) ~30-40ms: Цитата:
select
* from SalesPickingListJournalLine isum (nolock) where TST_01 like '%01Н0002320%' Цитата:
|--Compute Scalar(DEFINE-([isum].[TST_01]=[db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE].[TST_01] as [isum].[TST_01]))
|--Parallelism(Gather Streams) |--Nested Loops(Inner Join, OUTER REFERENCES-([Bmk1000])) |--Compute Scalar(DEFINE-([isum].[TST_01]=CONVERT(varchar(100),[db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE].[PICKINGLISTID] as [isum].[PICKINGLISTID],0))) | |--Index Scan(OBJECT-([db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE].[I_806DELIVERYREQUESTIDX] AS [isum]), WHERE-(CONVERT(varchar(100),[db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE].[PICKINGLISTID] as [isum].[PICKINGLISTID],0) like '%01Н0002320%')) |--RID Lookup(OBJECT-([db_cyr].[dbo].[SALESPICKINGLISTJOURNALLINE] AS [isum]), SEEK-([Bmk1000]=[Bmk1000]) LOOKUP ORDERED FORWARD) [TST_01] AS ([PickingListId] collate SQL_Latin1_General_CP1251_CI_AS) Последний раз редактировалось VitaliyK; 20.09.2007 в 14:40. |
#4 |
вот еще наблюдение
4 селекта: поиск в короткой строке в родном collation - длительность 630мс Цитата:
select *
from SalesPickingListJournalLine isum (nolock) where charindex ( ltrim ( rtrim ( isum.PickingListId ) ) , ',01Н0002320') > 0 Цитата:
select *
from SalesPickingListJournalLine isum (nolock) where charindex ( ltrim ( rtrim ( isum.PickingListId collate SQL_Latin1_General_CP1251_CI_AS) ) , ',01Н0002320') > 0 Цитата:
select *
from SalesPickingListJournalLine isum (nolock) where charindex ( ltrim ( rtrim ( isum.PickingListId ) ) , ',01Н0002320,01Н0002321,01Н0002322,01Н0002323,01Н0002324,01Н0002325,01Н0002326,01Н0002327,01Н0002328,01Н0002329') > 0 Цитата:
select *
from SalesPickingListJournalLine isum (nolock) where charindex ( ltrim ( rtrim ( isum.PickingListId collate SQL_Latin1_General_CP1251_CI_AS) ) , ',01Н0002320,01Н0002321,01Н0002322,01Н0002323,01Н0002324,01Н0002325,01Н0002326,01Н0002327,01Н0002328,01Н0002329') > 0 --collation сервера, базы и поля таблицы PickingListId - Cyrillic_General_CI_AS т.е. чем сложнее вычисления в Cyrillic_General_CI_AS тем хуже он в моих экспериментах по сравнению с SQL_Latin1_General_CP1251_CI_AS |
| Теги |
| collation, sql server, производительность |
| Опции темы | Поиск в этой теме |
| Опции просмотра | |
