Старый 07.02.2017, 10:11   #1
organicax: Attaching documents to RFQ
Источник: https://organicax.com/2017/02/06/att...uments-to-rfq/
When working with an RFQ often you have to share documents with the suppliers so they can see the details behind what you are asking for. This might be a parts list or engineering drawing for example. You can attach documents on the lines or on the case. Because this uses document handling they you can use all the document types that you have enabled.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Completing the RFQ for a requisition Blog bot DAX Blogs 0 04.02.2017 10:16
organicax: Creating an RFQ from a purchase requsition Blog bot DAX Blogs 0 04.02.2017 10:16
organicax: RFQ default payment terms Blog bot DAX Blogs 0 04.02.2017 03:29
organicax: RFQ Case number vs request for quotation number Blog bot DAX Blogs 0 04.02.2017 03:29
organicax: RFQ – Vendor Search Blog bot DAX Blogs 0 04.02.2017 03:29
Часовой пояс GMT +3, время: 21:30.
