Старый 06.08.2016, 03:27   #1
organicax: WMS Mobile device menu – Override target license plate
Источник: https://organicax.com/2016/08/05/wms...license-plate/
If you are setting up warehouse menu items there is an option override target license plate that you can select on some menu types like user directed, system directed. Which allows the user to override the license plate if picking a full license plate amount. The default behavior without this is to use the license plate of the first picked item.
Here is a quick overview.
AX2012 R3 CU10.
Cheers
Lachlan
Filed under: Warehouse management
За это сообщение автора поблагодарили: twilight (1).
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
organicax: WMS mobile device menu – Display disposition code Blog bot DAX Blogs 0 10.05.2016 17:11
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Часовой пояс GMT +3, время: 09:27.
