Старый 15.05.2009, 09:06   #1
Solutions Monkey: Passing parameters from Managed code to X++ in dataset
Источник: http://blogs.msdn.com/solutions/arch...n-dataset.aspx
In the user control code behing add an event handler to the CreatingDataSetRun event on the AxDataSource control
protectedvoid Page_Init(object sender, EventArgs e)
this.AxDataSource1.CreatingDataSetRun += newEventHandler(AxDataSource1_CreatingDataSetRun);
Set the param value to the event arugments void AxDataSource1_CreatingDataSetRun(object sender, CreatingDataSetRunEventArgs e)
e.DataSetRunArgs.parm = "4000";
In AOT override or add method in the data set and use element.args().parm() to received the paramter
public void executeQuery()
QueryBuildRange custRange;
custRange = SysQuery::findOrCreateRange(this.query().dataSourceNo(1), fieldnum(CustTable, AccountNum));
custRange.value(element.args().parm());
super();
You can also pass an Enum. For example
e.DataSetRunArgs.parmEnumType =
EnumMetadata.EnumNum(this.AxSession, "EPFormAction");
e.DataSetRunArgs.parmEnum(2);
public void init()
super();
if (element.args().parmEnumType() == enumnum(EPFormAction) && element.args().parmEnum() == EPFormAction::CreateMode)
//do somethign here
Dynamics AX: Microsoft Dynamics AX EP Team Blog - Filtering a DataSet from Code behind Blog bot DAX Blogs 0 04.12.2008 03:07
epblog: Filtering a DataSet from Code behind Blog bot DAX Blogs 0 18.11.2008 10:05
Solutions Monkey: Disabling Bound Fields through code Blog bot DAX Blogs 0 16.10.2008 00:05
Issues concerning X++: CLR interop: Passing Int16 values to managed code. Blog bot DAX Blogs 0 03.07.2007 00:31
Solutions Monkey: EP Samples from TechReady3 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 09:05.
