Старый 29.02.2020, 16:14   #1
thwidmer: Find Datatypes (updated)
Источник: https://thwidmer.wordpress.com/2020/...types-updated/
Update of my old script to D365
class FindEDT{ public static void main(Args _args) { #AOT Dialog dialog = new Dialog('Find EDT'); str searchString; DialogField dialogField = dialog.addField(extendedTypeStr(MCRSearchText), 'Search string'); boolean stopAfterFound; ; if(dialog.run()) { searchString = dialogField.value(); if(!strScan(searchString, "*", 1, 999)) //no "*" { searchString = "*" + searchString + "*"; } else if(strKeep(searchString,"*") == "*" && subStr(searchString,strLen(searchString),1)=="*") //just one final "*": beginns with { stopAfterFound = true; } info(strfmt("Find %1",searchString)); if(searchString) { setPrefix('Extended Data Types'); FindEDT::searchNodes(#ExtendedDataTypesPath, searchString, stopAfterFound); setPrefix('Base Enums'); FindEDT::searchNodes(#BaseEnumsPath, searchString, stopAfterFound); } } } static void searchNodes(str _basePath, str _searchString, boolean _firstonly) { #AOT TreeNode treeNode; TreeNodeIterator treeNodeIterator; SysDictType sysDictType; SysDictEnum sysDictEnum; Boolean found; ; treeNode = TreeNode::findNode(_basePath); treeNodeIterator = treenode.AOTiterator(); treeNode = treeNode.AOTfirstChild(); treeNode = treeNodeIterator.next(); while(treeNode) { if(treeNode.treeNodeName() like "*" + _searchString + "*") { if(_basePath == #ExtendedDataTypesPath) { sysDictType = sysDictType::newTreeNode(treeNode); } if(sysDictType) { if (sysDictType.extend() && sysDictType.enumId()) { info(strfmt("%1 (%2 - %3 -> %4)",treeNode.treeNodeName(), sysDictType.baseType() , extendedTypeId2name(sysDictType.extend()), enumId2Name(sysDictType.enumId()) )); } if(sysDictType.extend()) { info(strfmt("%1 (%2 - %3)",treeNode.treeNodeName(), sysDictType.baseType() , extendedTypeId2name(sysDictType.extend()) )); } else if (sysDictType.enumId()) { info(strfmt("%1 (%2 - %3)",treeNode.treeNodeName(), sysDictType.baseType() , enumId2Name(sysDictType.enumId()) )); } else { info(strfmt("%1 (%2)",treeNode.treeNodeName(), sysDictType.baseType())); } } else { info(strfmt("%1",treeNode.treeNodeName())); } found = true; } else if(_firstOnly && found) { return; } treeNode = treeNodeIterator.next(); } }}Run with the following link:
https://usnconeboxax1aos.cloud.onebo...er&cls=FindEDT
thwidmer: Electronic reporting by example: Create a new Bank file definition Blog bot DAX Blogs 0 31.01.2020 19:11
waldo: Where to find the Microsoft Dynamics 365 Business Central (and NAV) Docker Images (updated) Blog bot NAV: Blogs 0 01.02.2019 08:12
thwidmer: Comparison: “Use futures date as requirement date” Blog bot DAX Blogs 0 14.09.2017 13:11
Часовой пояс GMT +3, время: 00:08.
