Старый 04.02.2019, 15:11   #1
mfp: Mapping InventDim fields in an extension.
Источник: https://blogs.msdn.microsoft.com/mfp...-an-extension/
There are two table maps each mapping the fields of InventDim to concrete fields on other tables and entities: InventDimFieldsMap and InventInventoryDimensionEntityFieldsMapping. These maps provide common inventory dimension features such as copying and resolving dimensions. When you add a new inventory dimension, like Flavor, you must add Flavor fields to many tables and entities and...
alirazazaidi: Table method extension and grid field mapping Dynamics 365 for finance and operations Blog bot DAX Blogs 0 05.12.2018 02:27
mfp: New extension points Blog bot DAX Blogs 6 17.10.2018 12:54
mfp: InventDim in AX7 Blog bot DAX Blogs 19 03.03.2016 21:06
mfp: X++ in AX7: Extension methods Blog bot DAX Blogs 10 17.12.2015 18:22
Часовой пояс GMT +3, время: 04:39.
