Старый 23.07.2016, 05:04   #1
organicax: Setting up a new target market in call center
Источник: https://organicax.com/2016/07/22/set...n-call-center/
If you are setting up a call center then you can optionally setup a target market that you can use in your processes like assigning targets to a campaign.
When you setup a catalog for a call center and you associate a source code with the catalog then you can also associate the target market for the source code.
Here is a quick overview.
AX2012 R3 CU10
Cheers
Lachlan
Filed under: Retail
organicax: Catalog doesn’t show hierarchy for new call center Blog bot DAX Blogs 0 22.07.2016 22:13
organicax: Associating a call center to an organization hierarchy Blog bot DAX Blogs 0 22.07.2016 22:13
organicax: Setting up modes of delivery on a call center Blog bot DAX Blogs 0 14.03.2016 02:40
organicax: Creating a coupon for a discount and using on a call center sales order Blog bot DAX Blogs 0 11.03.2016 05:17
organicax: Enable price control on a call center Blog bot DAX Blogs 0 09.03.2016 03:28
Часовой пояс GMT +3, время: 23:22.
