Старый 11.01.2016, 20:08   #1
Art_Tanis is offline
Art_Tanis
Проблема с запросом
добрый день!
Вот такой запрос исполняется очень медленно. Не могу понять причину.
AX 2009 SP7.
static void _HTC_GetStockForItem(Args _args)
    Dialog                          dialog = new dialog();
    DialogField                     dlgItemId;
    DialogField                     dlgTransDate;
    ItemId                          itemId;
    TransDate                       transDate;
    InventSumDateValueReport        onhand;
    Qty                             qty;
    InventSettlement                inventSettlement;
    InventTrans                     inventTrans;
    InventTransPosting              inventTransPostingPhysical;
    dlgItemId = dialog.addFieldValue(typeid(ItemId),itemId);
    dlgTransDate = dialog.addFieldValue(typeid(TransDate),transDate);
    dialog.run();
    transDate = dlgTransDate.value();
    itemId = dlgItemId.value();
    //onhand = InventSumDateValueReport::newParameters(transDate,itemId);
    //qty = onhand.physicalQuantity();
    //info(strfmt("%1| %2", itemId, qty));
        while select forceplaceholders sum(CostAmountAdjustment) from inventSettlement
        index hint ItemDateIdx
        where inventSettlement.ItemId                 == itemId                           &&
              inventSettlement.Cancelled              == NoYes::No                        &&
              inventSettlement.TransDate              >  transDate                          &&
              /* <SYS>
              inventSettlement.SettleModel  == InventSettleModel::PhysicalValue
              </SYS> */
              // <GEEU>
              inventSettlement.SettleModel            == InventSettleModel::PhysicalValue &&
              inventSettlement.InventTransCurrency_RU == InventTransCurrency_RU::PrimaryCur
              // </GEEU>
    join TableId from inventTrans
        index hint RecId
        where inventTrans.RecId             == inventSettlement.TransRecId  &&
              (inventTrans.StatusIssue      == StatusIssue::Sold            ||
              inventTrans.StatusReceipt     == StatusReceipt::Purchased)    &&
              inventTrans.DatePhysical      <= transDate
    join IsPosted from inventTransPostingPhysical
        index hint DateVoucherTransIdx
        group by IsPosted
        where inventTrans.VoucherPhysical                           == inventTransPostingPhysical.Voucher           &&
              inventTrans.DatePhysical                              == inventTransPostingPhysical.TransDate         &&
              inventTrans.InventTransId                             == inventTransPostingPhysical.InventTransId     &&
              inventTransPostingPhysical.InventTransPostingType     == InventTransPostingType::Physical             &&
              inventTransPostingPhysical.IsPosted                   == inventSettlement.Posted
                qty = -inventSettlement.CostAmountAdjustment;
Проблема такая - у меня на ноутбуке исполняется мнгновенно. На сервере с 32 гигами оперативки исполяется запрос 5 секунд.
Подскажите как посмотреть в чем дело?
Проблема с запросом Borsugg DAX: Программирование 7 22.11.2013 15:17
Проблема с запросом Raduga DAX: Программирование 7 07.04.2010 14:00
Проблема с SQL запросом kalex_a DAX: Программирование 15 31.03.2010 11:28
Проблема с запросом kalex_a DAX: Программирование 2 17.08.2009 08:05
Проблема с запросом Protey DAX: Программирование 7 10.07.2006 09:32
Часовой пояс GMT +3, время: 19:59.
