Старый 16.10.2015, 21:11   #1
emeadaxsupport: A few performance considerations for Multisite activation in MS Dynamics AX 2009 SP1
Источник: http://blogs.msdn.com/b/axsupport/ar...-2009-sp1.aspx
If you want to upgrade to any MS Dynamics AX 2012 version (R1, R2, or R3) from MS Dynamics AX 2009 then it is a needed requirement to run the multisite activation on the MS Dynamics AX 2009 side as a prerequisite.
The multisite activation process is known to be a quite performance intensive task!
Therefore I just like to recommend the following tips for the environment where you run the multi site activation:
Tips:
* Make sure that you run a distributed installation where the AOS server and SQL servers run on different computers
* Make sure that the AOS server and SQL server run 64 Bit Windows operating systems instead of 32 Bit Windows operating system due to enhanced main memory handling
* If possible prefer physical hardware for the AOS and SQL server instead of virtual machines if possible
* Check that “High Performance” under Control Panel, Power options is set for the AOS server, SQL server machine and AX client computer. You may find more information about the setup / background of the “High Performance” setting  here: http://blogs.msdn.com/b/axsupport/ar...r-options.aspx
* Make sure that the CPU clock speed of AOS and SQL server computer is >= 3 GHz
Addtional information:
You can find more application related  background information in the  MS Dynamics AX 2009 multisite activation white paper here:
http://www.microsoft.com/en-gb/downl....aspx?id=12840
Some upgrade related information about MS Dynamics AX 2009 multisite activation can listed here:
http://blogs.msdn.com/b/axsupport/ar...e-process.aspx
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 6 Blog bot DAX Blogs 0 01.09.2014 14:11
emeadaxsupport: Installation of MS Dynamics AX 2009 SP 1 on Windows XP SP 3 Blog bot DAX Blogs 0 22.06.2014 21:16
emeadaxsupport: Overview of AX build numbers Blog bot DAX Blogs 3 24.05.2012 19:44
Часовой пояс GMT +3, время: 03:49.
