Старый 27.11.2012, 08:11   #1
Malaysia: Building the Browse for Folder lookup
Источник: http://axmas.blogspot.com/2012/11/bu...er-lookup.html
1. In the AOT, open the LedgerParameters table, and create a new field with the
following properties:
Property Value
Type String
Name DocumentPath
Label Documents
ExtendedDataType FilePath
2. Add the newly created field to the bottom of the table's General field group.
3. In the AOT, open the LedgerParameters form, and create a new method with the
following code:
public str filePathLookupTitle()
return "Select document folder";
4. To test the results, open General ledger | Setup | General ledger parameters, and notice the newly created Documents control, which allows you to select a folder:
Malaysia: Building a tree lookup Blog bot DAX Blogs 0 26.11.2012 18:11
Malaysia: Using a form for building a lookup Blog bot DAX Blogs 0 26.11.2012 11:11
Malaysia: Building a selected/available list Blog bot DAX Blogs 0 14.11.2012 14:11
Malaysia: Building a dynamic form Blog bot DAX Blogs 0 07.11.2012 17:11
Malaysia: Lookup Blog bot DAX Blogs 0 30.10.2012 15:11
Часовой пояс GMT +3, время: 05:33.
