Старый 16.11.2011, 21:14   #1
daxmusings: Trusted Intermediary in AIF Services
Источник: https://community.dynamics.com/produ...-services.aspx
The use of WCF as the platform for AIF in AX 2012 makes integrating relatively simple. Most recent products and programming languages support SOAP or REST services, or Odata. There is one big catch with the services in AX however… users need to...(read more)
AIF: Microsoft Dynamics AX 2012 Services and AIF White Papers Blog bot DAX Blogs 0 16.06.2011 00:11
axinthefield: The AIF processing services used by each of the AIF adapters in AX 2009 Blog bot DAX Blogs 0 27.05.2011 05:12
ukax: Application Integration Framework (AIF) Document Services Workshop Blog bot DAX Blogs 0 24.01.2011 20:11
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Часовой пояс GMT +3, время: 04:52.
