Старый 10.09.2021, 04:44   #1
d365technext: Updating the cross-references
Источник: https://d365technext.blogspot.com/20...nceD365FO.html
Cross Reference Dynamics Finance & Operations
  • Navigate to MS Dynamics AX > Tool > Development Tools > Cross-reference > Periodic > Update
  • The Update cross-reference window appears.
  • Select update all and click the OK button. It will create a batch job and start running the batch job.
  • Usual time ranges from 3-4 hours depending upon the performance of the server.
ievgensaxblog: Advanced cross-reference search. Blog bot DAX Blogs 0 26.11.2017 05:38
sashanazarov: Generate a project with application objects from "used by" cross-references Blog bot DAX Blogs 0 30.05.2013 13:11
addicted2ax: Dynamics AX 2012 & SQL Server 2008R2: Cross Join vs. Inner Join – Houston we have *NO* Problem Blog bot DAX Blogs 0 20.12.2012 20:11
AX Developer tips: Dynamics AX Performance issue. Cross object references drawbacks. Blog bot DAX Blogs 0 14.07.2008 00:11
Dynamics AX Geek: cross-references & find Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 19:02.
