Старый 10.07.2020, 04:03   #1
How to activate a financial dimension
Источник: http://alexvoy.blogspot.com/2020/07/...dimension.html
First, run the following script over your DB via SQL Management Studio.
update SQLSYSTEMVARIABLES SET VALUE = 1 where PARM = 'CONFIGURATIONMODE'
select value from SQLSYSTEMVARIABLES where PARM = 'CONFIGURATIONMODE'
Then restart IIS from inside of Visual Studio.
Activate your financial dimension.
Now, run the same script but by setting the variable to zero, and restart IIS again.
update SQLSYSTEMVARIABLES SET VALUE = 0 where PARM = 'CONFIGURATIONMODE'
How to concatenate financial dimension values in a View for a given hierarchy Blog bot DAX Blogs 1 20.08.2019 15:11
alirazazaidi: How to copy financial dimension form one object to other. Dynamics 365 For finance and operations Blog bot DAX Blogs 0 28.03.2019 03:33
How to lookup and set a new value for Financial dimension Blog bot DAX Blogs 0 03.10.2015 02:35
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 21:28.
