Старый 24.11.2011, 11:11   #1
daxdilip: Tip - How to get a blank InventDimId out
Источник: http://feedproxy.google.com/~r/blogs...dimid-out.html
Today, while writing a QueryRange, I had to pass a blank InventDimid. Initially, to make life easier ;-). I just put "BLANK".
Then, just did a bit of search and found that InventDim has a static method inventDimIdBlank which was exactly what I required. It returns "AllBlank". Many of you guys might be knowing this one, but just for the ignorant out there (including me) :-) this is a handy tip
InventDim::inventDimIdBlank()
Последний раз редактировалось Poleax; 24.11.2011 в 11:24. Причина: оформление
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 17.05.2011 11:11
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 12.05.2011 08:11
daxdilip: Tip How to Trace a Call to an AIF Web Service Blog bot DAX Blogs 0 26.11.2010 00:12
daxdilip: Tip: How to display the AOS Name at the status bar Blog bot DAX Blogs 5 15.11.2010 13:55
Часовой пояс GMT +3, время: 01:46.
