Старый 13.05.2011, 19:38   #1
ideveloper is offline
ideveloper
Best Practice for AiF Queries 2
Hi.
I have a query composed of an AIF Service which contains following tables
CustTable->XXXTable->EmplTable->DirPartyECommRelShip->DirEComAddr
Now I need another service for another purposes which starts with the first 3 tables, but ends with the Adress table.
Should I create a separate Query or should I use the first Query and expand it with the Adress table?
(And turn on the required fields in the Endpoints (see Best Practice for AiF Queries Best Practice for AiF Queries))
Regards
ideveloper
Старый 16.05.2011, 07:20   #2
Sergikrus is offline
Sergikrus
You can create your own query, but based on his AIF Service.
Старый 16.05.2011, 11:43   #3
ideveloper
Hi.
Thank you for your answer.
Could you tell me please, how to do it.
I have not seen any possibilities to inherit the existing Query???
Regards
ideveloper
Старый 16.05.2011, 15:58   #4
Maximin is offline
Maximin
415 / 361 (13) ++++++
No, there's no such possibility. Just copy-paste.
I have custom class to simplify keeping data policies on Endpoint in sync for such cases.
Последний раз редактировалось Maximin; 16.05.2011 в 16:00.
Старый 17.05.2011, 07:43   #5
Sergikrus
Сообщение от ideveloper Посмотреть сообщение
Hi.
Regards
ideveloper
Then tell better than me:
Channel9: Microsoft Dynamics AX 2009 AIF Web Services Screencast
It creates any query in the AOT. Well, then the query is sent to the wizard to create services AIF
Последний раз редактировалось Sergikrus; 17.05.2011 в 07:50.
Старый 17.05.2011, 20:01   #6
ideveloper
Thank you for your replies
Sergikrus: I am familar with this method. It is simple to use. But I was hoping, that there is a possibility to inherit the queries and throw away tables which are not needed. If I duplicate a Query and create a service with the AiF-Wizard I get new Classes according to the new Query which have the same functionality like the Classes from the "Parent"-Query.
It is not only the Query which is duplicated, there are Classes too.
aif, endpoint, query
sumitax: AX2009 – Best Practice Check for Classes Blog bot DAX Blogs 0 18.02.2011 17:11
AX UK: Building a Microsoft Virtualisation & Management Practice Blog bot DAX Blogs 0 17.02.2010 21:07
DeniZone: RunBase - classes and Best Practice Blog bot DAX Blogs 0 12.12.2008 13:05
Code Access Security - ошибка Best Practice Vhaldemar DAX: Программирование 9 05.11.2008 11:48
Часовой пояс GMT +3, время: 14:15.
