Старый 11.03.2009, 19:05   #1
axaptapedia: Dimensions
Источник: http://www.axaptapedia.com/Dimensions
Summary:
==Programming against dimensions==
The usual method of programming against a specific dimension in Ax is as follows:
salesTable.Dimension[SysDimension::Center + 1] = 'The cost centre';
However, this code is not technically correct. It relies on the enum value of the dimension matching the array dimension (plus 1), which is not guaranteed. If a developer follows Microsoft's best practice guide and gives a non-sequential enum value to a new financial dimension (e.g. 100) then the code will not work.
It is better to use the following pattern when assigning to/reading from specific dimensions in X++ code. This maps the dimension to the correct array index, irrespective of the enum value.
salesTable.Dimension[Dimensions::code2ArrayIdx(SysDimension::Center)] = 'The cost centre';
dimensions
palleagermark: Adding new financial dimensions to AX Blog bot DAX Blogs 1 17.02.2009 13:03
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
jerry-dynamics: dimensions hierarchy controls Blog bot DAX Blogs 0 16.06.2007 11:20
Часовой пояс GMT +3, время: 12:53.
