Старый 18.07.2008, 02:13   #1
AppDoc Bug: HTMLHelpFile property is unavailable in DAX2009
Источник: http://alexvoy.blogspot.com/2008/07/...operty-is.html
As far as I see neither this property nor HTMHelpTopic are available for newly created objects in Application Documentation branch of AOT even if I set HTMLFileEnabled to Yes.
The only cure is to restart the client.
Moreover, after that if you first choose anything but your newly created object in Application Documentation branch (if you e.g. search for it by typing its first letters of the name) or the current element you are working with in the branch loses the focus that is the case - you now cannot change these properties.
Correct me, please, if I lost something.
palleagermark: Bug in EP 2009 when having the debug flag set to true Blog bot DAX Blogs 0 05.01.2009 11:06
Вопросы по OLAP в DAX2009 oleg_e DAX: Функционал 9 10.12.2008 02:02
Ruslan Goncharov: Dynamic enabled() property for StringEdit and arrows Blog bot DAX Blogs 0 18.04.2008 20:05
Ruslan Goncharov: Mandatory property for DialogField Blog bot DAX Blogs 1 29.12.2007 20:48
Kashperuk Ivan: A bug in validation of methods' access modifiers and class abstract modifier Blog bot DAX Blogs 0 27.06.2007 21:40
Часовой пояс GMT +3, время: 11:26.
