Старый 19.06.2023, 12:12   #1
25,495 / 847 (79) +++++++
ievgensaxblog: MSDyn365FO. Truncate a table.
Источник: https://ievgensaxblog.wordpress.com/...ncate-a-table/
Now when storage capacity report is available you may want to clean up some data. One of the top one’s to grow out of control is document attachment history. You have standard batch job for the clean up, but if you have millions of records, it may take too long because that batch deletes only 50000 in a time.
Using custom script you can delete them in no time!
public static void main(Args _args){ ttsbegin; new SqlDataDictionaryPermission(methodstr(SqlDataDictionary, tableTruncate)).assert(); new SqlDataDictionary().tableTruncate(tableNum(DocuHistory), false); CodeAccessPermission::revertAssert(); ttscommit;}
create procedure sys.sp_tables при синхронизации Logger DAX: Администрирование 0 27.06.2019 12:33
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
waldo: Delete all records in table with C/AL – Truncate Blog bot NAV: Blogs 0 30.06.2016 05:19
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Часовой пояс GMT +3, время: 09:47.
