Старый 03.06.2020, 18:11   #1
crmtipoftheday: Tip #1360: Customizing the activity timeline
Источник: https://crmtipoftheday.com/1360/cust...ivity-timeline
You migrate data to Dynamics 365/Common Data Service and in the migration, you close activities. After the migration, the activity timeline shows the migration account in the top line of every activity.
Say you want to have the timeline display something other than the account who closed the task. How do you customize this layout?
  1. Open the form in the legacy customization experience.
  2. Go to properties of the timeline/social pane
  3. Click the activity tab and change “display activity using” to “card form.”
From the “select a card form for each activity” section, select the card form you want to use for each activity type–change the activity type and select the card form you want to display in the timeline.
If you don’t want to show the modified by, remove it from the card form.
Be careful when editing the card form–if you make too many changes, the timeline may stop working correctly–be sure you test any changes that you make before releasing them.
Cover image: Wikimedia Commons
crmtipoftheday: Tip #1231: Activity Quick Create in Unified Interface Blog bot Dynamics CRM: Blogs 0 12.03.2019 18:11
crmtipoftheday: Tip #1188: The case of the missing activity tab Blog bot Dynamics CRM: Blogs 0 09.11.2018 05:04
crmtipoftheday: Tip #1184: Custom activity in Timeline Blog bot Dynamics CRM: Blogs 0 01.11.2018 16:12
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 14:44.
