Старый 17.03.2020, 07:13   #1
crmtipoftheday: Tip #1332: Open forms as a dialogs in model-driven apps
Источник: https://crmtipoftheday.com/1332/open...l-driven-apps/
Today’s tip comes from Eric Regnier. You can send your tips to jar@crmtipoftheday.com.
One of the small but awesome new features in 2020 Wave 1 are the modal dialogs. In many implementations, common feedback we hear from customers is around UX with too many clicks or navigation between screens. With this new feature, it enhances the UX by enabling the ability of creating and editing data in forms without navigating away. And it’s available for early access so check it out!
This can be achieved by using Xrm.Navigation.navigateTo function. You can use it to create new or update existing records. Here’s an example:
Xrm.Navigation.navigateTo({ pageType:"entityrecord", entityName:"account", formType:2, entityId:"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"}, { target: 2, position: 1, width: {value: 80, unit:"%"}});What’s even better is that the code above will work currently but will open the record in a new window instead of modal. So you can prep your code now and will work seamlessly when Microsoft releases it
survivingcrm: Canvas Apps for the Model-driven mind: how to make that leap Blog bot Dynamics CRM: Blogs 0 30.08.2019 15:11
crmtipoftheday: Tip #1249: Talk back from canvas to model-driven Blog bot Dynamics CRM: Blogs 0 10.04.2019 05:19
crmtipoftheday: Tip #1226: Avoid Model-Driven Failure Blog bot Dynamics CRM: Blogs 0 05.03.2019 14:11
crmtipoftheday: Tip #1209: Embedding canvas apps in model-driven forms Blog bot Dynamics CRM: Blogs 0 12.12.2018 14:11
Часовой пояс GMT +3, время: 19:56.
