Старый 12.09.2019, 20:14   #1
msdn.microsoft.com/nav: Using Power Platform Dataflows to extract and process data from Business Central – Post 1
Источник: https://cloudblogs.microsoft.com/dyn...entral-post-1/
How do you get data out of Business Central so that you can use it in other systems? For example, how can you visualize Business Central data in Power BI or analyze it in Azure Databricks? The main way to get data out of Business Central (and in again for that matter) is through the
Read more
The post Using Power Platform Dataflows to extract and process data from Business Central – Post 1 appeared first on Dynamics 365 Blog.
survivingcrm: The Real Common Data Service Emerges Blog bot Dynamics CRM: Blogs 0 08.04.2019 22:12
emeadaxsupport: Calling AX 2012 Business Logic from SSIS Using a Script Task and Custom Web Service Blog bot DAX Blogs 0 12.11.2015 03:48
axsa: Power BI and Dynamics AX: Part 2: Extract and Transform Blog bot DAX Blogs 0 20.02.2015 19:14
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
Часовой пояс GMT +3, время: 19:34.
