Старый 08.03.2019, 18:22   #1
crmtipoftheday: Tip #1229: Use math to make your chart look good
Источник: https://crmtipoftheday.com/1229/use-...art-look-good/
It’s Friday afternoon and the management asked you to create a quick chart illustrating your team’s bug handling pipeline. Easy-peasy.
Step 1 – extract data from the Squash-A-Bug system
StatusCountNew4268Under Review1921Planned516Completed229Step 2 – visualize it as a small dashboard:
That…. does not… look… good… (tried funnel – that’s even worse)
We appear to be choking under the flood of new bugs… It’s Friday, for crying out loud, can’t give bad news to the management!
(busily searches dusted brain corners for the high education leftovers)
Found!
Here’s your tip of the day:
If your numbers are disproportionally skewed, use the logarithmic scale. It brings the values “closer together”
Tîpp Jäår
And the end result:
Ahhh, that’s much better. Take that, management!
Friday night, here I come!
Thank you, Dynamics 365 for the idea (pun intended), and Crissy Jarvis on Unsplash for the cover photo.
crmtipoftheday: Tip #1139: Giving Good Demonstration Blog bot Dynamics CRM: Blogs 0 23.07.2018 14:11
crmtipoftheday: Tip #1126: Recycling Entities Does Not Always Make Sense Blog bot Dynamics CRM: Blogs 0 04.07.2018 18:12
crmtipoftheday: Tip #1103: Chart styling cheat sheet Blog bot Dynamics CRM: Blogs 0 08.04.2018 03:03
crmtipoftheday: Tip #1097: Change chart labels on currency values to show in Millions or Thousands Blog bot Dynamics CRM: Blogs 0 04.04.2018 08:11
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
Часовой пояс GMT +3, время: 02:17.
