Старый 14.05.2018, 06:12   #1
crmtipoftheday: Tip #1114: Check scalability of your PowerApp
Источник: https://crmtipoftheday.com/1114/chec...your-powerapp/
PowerApps are very expressive when it comes to data filtering, sorting, and other data manipulations. To maximize the application performance, PowerApps have a concept of delegation where PowerApps will delegate the processing of data to the backend instead of pumping data to the app for local processing.
For your application to scale it’s important to use delegable queries so that the backend does most of the heavy lifting. To quickly check if you’re using non-delegable queries anywhere click on File > App Settings > Experimental Features and then set the data row limit to 1:
From that moment, all your delegable queries will continue to run normally while non-delegable ones will return precisely one row. So when you see a single row in the results where more is expected, you know that you have something to work on!
Facebook and Twitter cover photo by William Bayreuther on Unsplash
crmtipoftheday: Tip #1103: Chart styling cheat sheet Blog bot Dynamics CRM: Blogs 0 08.04.2018 03:03
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
Часовой пояс GMT +3, время: 23:39.
