Старый 24.03.2018, 00:15   #1
crmtipoftheday: Tip #1092: Chrome trick to make new field appear in the list
Источник: https://crmtipoftheday.com/1092/chro...r-in-the-list/
Browsers to Dynamics 365 are like a set of screwdrivers to a random screw. Sometimes you need a Phillips, sometimes – flathead, and on odd occasion HP hex is required. We already covered browsers war in the past but not a day goes by without a new discovery.
Consider, for example, today’s training session by yours truly. (I have to say that Dynamics training sessions are great – not only you get to share knowledge with the attendees, but more often than not, seasoned students gift a few nuggets). This afternoonDaniel patiently observed my struggle with Chrome, you know, the one where you edit a form, click New Field to add something on the fly only to discover that the field does not appear in the list, as it does in other browsers. I used to close and reopen the form to make the new field available but turns out that the solution is to click New Field again and then close the dialog without entering anything. Presto! – new field is now in the list. Thanks, man!
Morale of the story: when you can’t find the screwdriver to match the screw, drilling the bugger out always does the trick.
crmtipoftheday: Tip #1054: Hiding Field Service fields Blog bot Dynamics CRM: Blogs 0 16.01.2018 01:12
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
german_nav_developer: Upgrade Tips & Tricks Teil 3 Blog bot NAV: Blogs 0 17.03.2017 13:11
Часовой пояс GMT +3, время: 10:31.
