Старый 22.11.2016, 13:11   #1
dynamicsaxse: New version of Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) is now available
Источник: https://blogs.technet.microsoft.com/...now-available/
A new version (v 2.0.37.0) of Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) is now available on LCS Tools.
Below are the list of issues that has been fixed in this new version:
 IDMF – Support with SQL Server 2016
 IDMF – Revert and Restore Archive deletes in one transaction : Revert and restore operations do not delete data in archive database deletions in batches but as a single transaction. The solution is to implement batch size functionality and introduce transaction level deletion.
 IDMF: Timeout exception when deleting the data from archive table: This issue must be caused by Command Timeout being set to default.
 IDMF – Restore archive data job for large number of records is not restoring all records as expected
NAV Team: Upgrade Toolkit for Upgrading Data from Microsoft Dynamics NAV 2009 R2 and Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 22.11.2013 20:00
palleagermark: Intelligent Data Management Framework For Microsoft Dynamics AX (Pre-Release) Blog bot DAX Blogs 0 01.07.2009 00:05
Часовой пояс GMT +3, время: 21:12.
