Старый 14.09.2010, 11:52   #1
You can find any page, report, or Departments view in your installation by using the Search box to the right of the Address box. In this way you reduce the amount of time you spend searching.
When you start typing characters in the Search box, a drop-down list shows page and report names containing the character(s) you type. The drop-down list changes as you type more characters, and you can select the correct page or report from the list when it is displayed. The second column in the drop-down list shows the navigation paths to the found pages and reports. You can select the path in the second column to navigate to the Departments page where the page or report exists.
Here are the detailed steps for searching for pages, reports, and Departments views from the Role Center.
1. In the Search field in the top right corner, type "sales".
2. Continue typing with "invoices".
The second column in the drop-down list shows the navigation paths to the found pages and reports and you can select the path to navigate to the Departments page where the page or report exists.
3. Select either the page or report in the first column of the search results or the path in the second column of the search results.
For more information about usability and the RoleTailored client, see the blog post Useful, Usable, and Desirable.
Источник: http://feedproxy.google.com/~r/Micro...le-center.aspx
Старый 15.09.2010, 12:55   #2
GalaM is offline
GalaM
640 / 42 (3) +++
Удивительно полезная функция .
можно вообще не знать, где расположена та или иная функция, а знать только название формы/отчета...
Сама хотела написать пост про эту чудо функцию , но коллеги сделали это для всего мира
Старый 15.09.2010, 23:55   #3
Romul is offline
Romul
Сообщение от gala Посмотреть сообщение
Лень рыться в архивах http://blogs.msdn.com/b/nav/ , но эта фича описывалась чуть ли не в первую же неделю после выхода SP1 W1.
Странно...
Старый 16.09.2010, 10:51   #4
GalaM is offline
GalaM
640 / 42 (3) +++
Сообщение от Orwell Посмотреть сообщение
Странно...
Ну а что, тут странного, теперь решили про нее написать . Освежить знания тех, кто только начал работать с NAV 2009 SP1.
На руссом языке писать не было смысла, так как только сейчас версия появилась. Да и по картинкам все понятно.
Часовой пояс GMT +3, время: 15:47.
