#1 |
kurthatlevik: AX RTW – Hack to enable configuration mode
Источник: https://kurthatlevik.wordpress.com/2...guration-mode/
============== When downloading the AX RTW local VM from connect, you often want to disable some configuration keys. (Like catch weight etc). But now you will see the following warning; “This form is read-only unless the system is in the maintenance mode. Maintenance mode can be enabled in this environment by running maintenance job from LCS, or using Deployment.Setup tool locally” ![]() This warning is to prevent that configurations are enables/disabled, and that the system is set in maintenance mode. There are 2 ways of dealing with this.
After that, you can change configurations. But make sure you never EVER do this in a production environment! Hacking DAX’ing J ![]() Источник: https://kurthatlevik.wordpress.com/2...guration-mode/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
