Старый 26.06.2015, 21:11   #1
gustafwesterlund: Non breaking Space in SSRS
Источник: http://gustafwesterlund.blogspot.com...e-in-ssrs.html
Been working with creating classical reports in SSRS for a customer lately and there are some tricks that you sometimes need to employ. Today, I found one, so this article will be short. Non-breaking space in SSRS can be set as an expression with the value "=char(160)",
White Sands - a sort of white space - broken by some tracks.If using IIF or just adding it to the end of the line is up to you. It is at least good to know.
That was a short post and the tensions is building towards the 1:st. If you don't know why, check back on the 1:st and you'll know why.
Gustaf Westerlund
MVP, Founder and CTO at CRM-konsulterna AB
www.crmkonsulterna.se
kamalblogs: SSRS Tip: Printing Row headers in every page – Dynamics Ax 2012 Blog bot DAX Blogs 0 23.09.2013 16:12
bojensen: How to Set the Query Range on a SSRS Report | Amir’s Microsoft Dynamics AX space Blog bot DAX Blogs 0 18.03.2013 17:11
DynamicsAxSCM: Monitor and analyse current and future warehouse space utilization with Dynamics AX 2012 R2 Blog bot DAX Blogs 1 13.12.2012 01:01
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 13:16.
