Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 12.09.2014, 14:15   #1
ist is offline
ist
Using Dynamics AX HTML control
Hi All,
My question is related to using html control in form design.
I had to do changeable table structure which rows and colums number depends on some condition. The content of table cells is plain text. The choice was to use table control. I have done this solution and everything seems to be OK, but somethimes the table control not well redraws.
I decided to use html control, so I altered the function that builds table control so that it does html document and passed it to html control. Everything works fine.
Now I have to do table cell click event, so that when the user clicks on table cell, some buttons (from AX form design, not in html) to be enabled/disabled depends on clicked table cell content. First I had to get the content from table cell. I could do this through Javascript like this:
Код:
<script language="javascript" type="text/javascript">
 var table = document.getElementById("tbl");
 if (table != null) {
     for (var i = 0; i < table.rows.length; i++) {
         for (var j = 0; j < table.rows[i].cells.length; j++)
             table.rows[i].cells[j].onclick = function () {
             tableText(this);
 function tableText(tableCell) {
     alert(tableCell.innerHTML);
 </script>
but how could I pass innerHTML (clicked table cell content) to AX?
I saw that html control has a method getElementById() which returns COM object, so I override onClick() event method on html control (right click on html control and choice ActiveX Explorer), but I don't know how to use COM object so that I can get innerHTML.
Is there anyway to get html table cell content by X++ instead by Javascript?
Regards,
ist.
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
atinkerersnotebook: Configuring Production Control Within Dynamics AX 2012 Downloadable As PDF Blog bot DAX Blogs 0 01.07.2014 22:11
Часовой пояс GMT +3, время: 15:10.
