Старый 01.11.2011, 03:13   #1
crminthefield: CRM Online Performance Troubleshooting Ideas
Источник: http://blogs.msdn.com/b/crminthefiel...ing-ideas.aspx
The CRM Online performance topics listed below are general ideas that should be considered when working through performance issues. I will do my best to update this blog entry with new content when it becomes available.
Questions To Ask
Before digging in, we’ll need to get a better understanding of the performance issues that the user is experiencing. I’ve listed some of the questions that you’ll want to consider below. The answers to these questions
  • General
    • What OS is being used?
    • What is the total memory on the machine
    • Can the issue be reproduced in another CRM Online environment?
    • Does the issue repro in the CRM web client, CRM Outlook client, or both (it will be important to verify this)?
      • If the issue reproduces in the CRM web client, troubleshoot there first as there are other layers of the CRM Outlook client that could slow you down to reaching the root cause.
    • What version of Office is being used (only relevant if we’re dealing with a CRM Outlook client issue)
    • If the issue is occurring on the CRM Outlook client, what Update Rollup is currently on the user's machine (this can be verified by getting the version of the crmaddin.dll…located in the Microsoft Dynamics CRM\Client\bin directory or by clicking the About Microsoft Dynamics CRM button within the Outlook client?
  • Magnitude of the issue
    • How many users are experiencing the issue?
    • Can the issue be consistently reproduced, or does it happen sporadically
    • Does the performance issue happen only in certain areas of the CRM Online application? If so, what area(s)
    • If the issue is happening sporadically, does it seem to be occurring during a certain time of the day, or when a certain process is running?
  • Performance related
    • What type of internet connection does the user(s) have?
    • Do multiple users experience this issue during the same period of time, or does it appear to be a one-off performance issue
    • What country is the CRM Online datacenter located in
    • What country is the user experiencing the issue accessing CRM from?
Network Issues
One of the first things that we can do to verify where the issue lies is to verify whether or not the network (mainly bandwidth or latency) seems to be part of the problem. Low bandwidth and high latency will negatively impact the end-user CRM Online experience. It is a good idea to test WAN performance at the beginning of the troubleshooting process. Our CRM Online R&D team has created a CRM Online Network Performance tool that gathers client network configuration data.
The client latency tool provides insight into the network conditions you are working with. It’s important to note that CRM Online is designed to work best over networks with latency under 150 milliseconds and bandwidth greater than 50 KB/s. These numbers are provided as general performance guidelines rather than guarantees.
Browser Related
Client-side browser settings can have a significant impact on the performance of the CRM Online application. The items listed below are a few items to consider:
  • For optimal CRM Online performance, use the latest IE browser (currently IE9 at the time of this blog). IE9 includes JavaScript acceleration functionality to help improve client-side performance.
  • By default, Windows Internet Explorer 7 and earlier versions limit the number of files that you can download at one time to two. Windows Internet Explorer 8 limits the number of files that you can download at one time to six. This change reflects the faster connection speeds that are now typical for most users. Note that for dial-up connections, the limits from earlier versions still apply. If you find that you are running on a version prior to IE8, you may want to follow the steps listed within the “Optimizing and Maintaining the Performance of Microsoft Dynamics CRM Clients” to increase the MaxConnection settings.
  • IE Internet Option Settings:
    • Internet Options – General – Browsing History – Temporary Internet Files and History Settings – Check for newer versions of stored pages. Verify that Automatically is selected.
    • Internet Options – General – Browsing History – Temporary Internet Files and History Settings – Disk space to use. Verify that a value from 50 to 250 MB is selected (the closer to 250 MB, the better).
    • Internet Options – General – Browsing History. Verify that “Delete browsing history on exit check box is cleared to prevent the deletion of temporary Internet files each time that the browser is closed.
    • Internet Options – Advanced – Security. Verify that the “Do not save encrypted pages to disk” check box is cleared, and then click OK.
Note: After the client-side browser settings on a computer are modified, loading the Dynamics CRM Web client for the first time (the “cold” load) may take several moments longer than usual. Subsequent page loads (“warm” loads) will show improved performance, however, as many of the Microsoft Dynamics CRM Web pages will have been cached during the initial load.
Customizations
When optimizing the performance of Microsoft Dynamics CRM clients, keep in mind that client performance is directly affected by the:
  • Number of (limit where possible):
    • Columns and grids in use
    • Rows returned per page
    • Quick find enabled fields
    • Sub-grids used on a page
    • Controls on a form (Form Design)
    • Controls on the ribbon
    • Client-side events (OnLoad, OnSave, OnChange)
  • Complexity and number of visualizations used in dashboards
  • Use of Jscript and Plugins. Advanced Jscript can add a significant amount of time to, open, save, close and other events especially if calls are made to Microsoft Dynamics CRM or other system. Plug-ins can also affect performance when saving.
If the issue is general slowness, can the user reproduce the issue in a CRM Online test environment with no customizations? It will be important to determine whether or not the issue is potentially related to customizations from the environment where the issue has been reproduced. Can any customizations be disabled in the environment for testing purposes (ex. OnLoad events)? If subgrids are contributing to the long form load times, it may be helpful to contract the subgrid sections as a test to see if performance improves. It is possible to contract sections by default on the load of the form, then expand the form shortly after.
CRM Online Configurable Settings
CRM Outlook Client Performance
There are several factors, specific to the CRM Outlook client, that can increase the amount of time that certain actions take to complete (ex. CRM Outlook client opening, navigating to a view, etc.). You’ll find some troubleshooting items below to test out:
  • Limit the number of views per entity
  • Limit the number of pinned views per entity
  • Limit the frequency at which customizations are published
  • Limit the number of columns within views
You may also see sluggish CRM Outlook client performance when the metadata file is being refreshed on the client machine. Metadata refreshes occur due to certain CRM Admin related activities, such as publishing customizations. To keep the metadata refresh minimal, publish customizations at a less frequent rate. Ultimately, the less that you publish customizations, the less you’ll see the metadata.xml file refresh. If you have installed additional MUI packs (language packs) that you aren’t using, it will be in your best interests to remove the packs that you aren’t using as those do add to the size of the metadata file. Some of the actions that push out a metadata refresh in CRM 2011 are:
  • Publishing customizations
  • Creating new CRM security roles
  • Modifying existing CRM security roles
Our CRM Online team is always attempting to improve the CRM Outlook experience. This includes incorporating new functionality, as well as improving performance and resolving any existing CRM Outlook client issues. Improving the CRM Outlook client in this way is done through Microsoft CRM Update Rollups. When running into CRM Online performance issues within the CRM Outlook client, it's always a best practice to download and install the most recent Update Rollup. Update Rollups can be found at the Microsoft Download Center. You can find the most recent CRM 2011 Outlook client Update Rollup by doing the following:
  • Navigate to: http://www.microsoft.com/download/en/default.aspx
  • Search for CRM 2011 Update Rollup
  • Set the Sort by option to "Newest to Oldest"
  • Once an Update Rollup is selected, you'll have two options to download for the CRM Outlook client:
    • CRM2011-Client-KBxxxxxxx-ENU-i386.exe for 32 bit versions of the Outlook client.
    • CRM2011-Client-KBxxxxxxx-ENU-amd64.exe for 64 bit versions of the Outlook client.
Tools
  • Fiddler
  • SQL Tools
    • In situations where more advanced SQL tracing is needed to determine long running queries and/or blocking, the Microsoft support team will need to be engaged. All previously mentioned levels of troubleshooting should be completed prior to this step.
- Jon
Microsoft Dynamics CRM Team Blog: Update Rollup 5 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 2 27.10.2011 17:11
crminthefield: CRM Online Performance: EnableRetrieveMultipleOptimization Blog bot Dynamics CRM: Blogs 0 30.09.2011 08:11
Часовой пояс GMT +3, время: 21:54.
