Старый 08.05.2011, 04:30   #1
Kashperuk Ivan: Tutorial: Table Relation properties in AX 2012
Источник: http://kashperuk.blogspot.com/2011/0...erties-in.html
As many of you already know, Microsoft has put in a lot of effort into normalizing the tables in AX 2012 and consolidating all the data modeling tools in one place - the table itself. As part of this effort, a number of new properties have been introduced on Tables, and in this post I would like to cover some of them, namely the properties on Table Relations.
The new properties you will find on a Table Relation in AX 2012 are:
  • Cardinality
  • RelatedTableCardinality
  • RelationshipType
  • Role
  • RelatedTableRole
  • UseDefaultRoleNames
  • CreateNavigationPropertyMethods
  • NavigationPropertyMethodNameOverride
Hua Chu from the AX team has written a Guideline document, explaining how these properties should be set for Relations you add to Tables in AX. Note that in AX 2012 most of the above information is not actually used at runtime. This is something that will happen in future releases.
I have modified the document so that it contains the information relevant for partners and customers extending the standard application and have uploaded it to my SkyDrive.
The document requires certain knowledge of Entity Relationship Modeling (ERM) and UML notation.
Disclaimer:
This document is intended as a guideline only, and should not be used as a Step-by-Step instruction.
Changes to any of the described functionality might still happen before AX 2012 RTM.
Your feedback and questions are, as always, welcome.
Старый 08.05.2011, 08:19   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Сообщение от Blog bot Посмотреть сообщение
Возможно, этот элемент отсутствует или недоступен
Возможно, элемент удален, его срок действия истек или отсутствует разрешение на просмотр. Дополнительные сведения можно получить у его владельца.
Старый 08.05.2011, 12:23   #3
Хмм. Странно.
Там в комментах парень запостил direct link. Можно скачать оттуда.
Вот он тоже:
http://wr4szw.bay.livefilestore.com/...ownload&psid=1
Последний раз редактировалось kashperuk; 08.05.2011 в 13:22. Причина: Добавил ссылку
Старый 09.05.2011, 00:06   #4
Хмм. Странно.
Вот он тоже:
Таак, что-то странное происходит с skydrive...
Выложил на своем сайте отдельно еще
Можно скачать отсюда
За это сообщение автора поблагодарили: Poleax (1), driller (2).
Kashperuk Ivan: Microsoft Dynamics AX 2012 Beta now available for download - please share your feedback Blog bot DAX Blogs 39 07.05.2011 00:50
Dianne Siebold: AX Tutorials in the AOT Blog bot DAX Blogs 0 05.12.2009 10:07
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Часовой пояс GMT +3, время: 06:49.
