Старый 15.03.2011, 20:12   #1
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 Sitemap Changes
Источник: http://blogs.msdn.com/b/crm/archive/...p-changes.aspx
Why doesn’t my new custom entity appear in the navigation pane?
If you are familiar with Microsoft Dynamics CRM 4, then you know that you can easily add a custom entity to any area in the sitemap navigation. When you select an area in the entity metadata editor, Microsoft CRM automatically modifies the sitemap to create an extra group called “Extensions” in the specified area for your custom entity.
In Microsoft Dynamics CRM 2011 changes to the sitemap are not visible until the sitemap is published. This is similar to how forms worked in previous versions. When you create a custom entity and add it to a specific group then you will need to publish the sitemap individually or “publish all customizations.” After publishing you can refresh your browser to see the changes.
Why is this group “unknown” showing up after upgrade?
If you customized the CRM 4 sitemap by adding a custom sub area to the settings area then you will get a group titled “unknownXX” after you upgrade your server to CRM 2011.
This occurs because there is no specified title for this group. The reason that you will see this only after you upgrade is because the CRM 2011 settings area is broken down into 4 new groups, whereas in CRM 4 everything was in a single group that unfortunately did not have a title. To fix this you just need to update your settings area similarly to:
<div style="padding-bottom: 0px; margin: 0px; padding-left: 0px; padding-right: 0px; display: inline; float: none; padding-top: 0px" id="scid:9D7513F9-C04C-4721-824A-2B34F0212519:c4f5ea39-e9c1-4ffe-bcab-df3314c5bcc7" class="wlWriterSmartContent">
Microsoft Dynamics CRM Team Blog: Troubleshooting Solution Import for your Upgraded Microsoft Dynamics CRM 2011 Organization Blog bot Dynamics CRM: Blogs 0 15.03.2011 01:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Book Club Blog bot Dynamics CRM: Blogs 0 02.02.2011 00:16
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Launch Time Blog bot Dynamics CRM: Blogs 0 12.01.2011 03:18
Microsoft Dynamics CRM Team Blog: Highlight: Available downloads for Microsoft Dynamics CRM Blog bot Dynamics CRM: Blogs 0 05.11.2008 22:05
Часовой пояс GMT +3, время: 15:26.
