Старый 10.12.2010, 04:17   #1
25,497 / 847 (79) +++++++
sumitax: Integrating SharePoint 2010 DLL with AX 2009 EP
Источник: http://sumitax.wordpress.com/2010/12...th-ax-2009-ep/
While working  Document Handling solution for Integration on Enterprise Portal in Dynamics AX2009 with SharePoint 2010 , following consideration.
  1. The SharePoint DLL should be deployed to each AX Client . Otherwise the code which instantiating the DLL would not compile.
  2. DLL needs to registered under “References” node in AOT under AX Client.
  3. Make sure code which  calls DLL method should run on the client . For example it should be placed on AX Dataset which calls the Wrapper Class  which in turn calls DLL methods.
Also we are working on a solution like WCF which is better than deploying the DLL to every client otherwise each time a DLL update would force DLL deployment to all AX Clients.
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
Rahul Sharma: MS SharePoint 2010 with Dynamics AX 2009 SP1 Enterprise Portal Blog bot DAX Blogs 0 12.10.2010 15:05
Часовой пояс GMT +3, время: 10:59.
