Старый 19.11.2010, 03:45   #1
Microsoft Dynamics CRM Team Blog: Update Rollup 14 for Microsoft Dynamics CRM 4.0
Источник: http://blogs.msdn.com/b/crm/archive/...s-crm-4-0.aspx
The Microsoft Dynamics CRM Sustained Engineering (SE) team released Microsoft Dynamics CRM 4.0 Update Rollup 14 on Thursday, November 18, 2010.
The links below will take you to the necessary information about Update Rollup 14.
General details about Update Rollup 14
Update Rollup 14 is cumulative. However, the Update Rollup 14 CRM Client and Data Migration Client packages require Update Rollup 7 to be installed. For all other CRM components, you do not need to install any previous Update Rollups prior to Update Rollup 14.
The Update Rollup 14 download contains updates for the 40 supported Language Packs. Prior to installing the Update Rollup 14 Language Pack, you must install the original Language Pack. If you have Language Packs installed, you should
  1. Download the Update Rollup 14 Language Pack
  2. Install the Update Rollup 14 Language Pack
  3. De-provision the Language Pack
  4. Re-provision the Language Pack
Information about how to avoid reboots when installing the CRM Outlook Client can be found in the Update Rollup 4 blog posting.
The Update Rollup 14 Client can be deployed before the server is upgraded to Update Rollup 14.
Steps to make the Update Rollup 14 Client available via AutoUpdate can be found in the Update Rollup 4 blog posting. The Link and Patch IDs can be found in KB article 2389019.
Each update rollup could have fixes that require manual configuration. Please see the “Hotfixes and updates that you have to enable or configure manually” section in KB article 2389019.
How to get support for Update Rollup 14
For support, please contact Microsoft Product Support. For a complete list of Microsoft Product Support Services telephone numbers and information about support costs, visit the following Microsoft Web site: http://support.microsoft.com/default.aspx?scid=fh;[LN];CNTACTMS.
Note: In special cases, charges ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The usual support costs will apply to additional support questions and issues that do not qualify for the specific update in question.
Cheers,
Matt Brown
Microsoft Dynamics CRM Team Blog: Update Rollup 12 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 3 02.08.2010 20:05
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 14.03.2009 07:10
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 4.0 Update Rollup Schedule Blog bot Dynamics CRM: Blogs 0 24.01.2009 04:12
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 20.01.2009 21:05
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Interviews and Screencasts Blog bot Dynamics CRM: Blogs 0 23.07.2008 03:18
Часовой пояс GMT +3, время: 06:27.
