Старый 09.11.2010, 19:04   #1
emeadaxsupport: When using AX 2009 AIF Web Services errors may not always get propagated
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ropagated.aspx
We came across an issue where we were using Microsoft Dynamics AX 2009 SP1 (Application and Kernel build 5.0.1000.52) and we have setup a custom AIF endpoint for a specific company, in which we have selected options to propagate errors and automatically respond to errors. However we find in certain circumstances when a message fails processing the detailed errors are not always propagated back.
The issue was identified in the AifRequestProcessor class. When we are processing an inbound message we switch to the company in which the message belongs to using the changeCompany() statement, however if an error is generated we switch back to the original company and then the error response message cannot always find the data it needs to make as the response (as it belongs to another company).
This issue was first resolved in AX 2009 SP1 Hotfix Rollup 5 (recorded as KB number 982450). The changes were made in Classes\AifRequestProcessor
--author:Tariq Bell--editor:Anup Shah--date:02/Nov/2010
emeadaxsupport: Unable to validate workflow URL in AX 2009 - Get the following error: The request failed with HTTP status 405: Method Not Allowed Blog bot DAX Blogs 0 07.07.2010 23:05
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Channel9: Microsoft Dynamics AX 2009 AIF Web Services Screencast Blog bot DAX Blogs 0 17.06.2009 17:05
Часовой пояс GMT +3, время: 11:00.
