Старый 23.04.2010, 12:05   #1
paruvella: Generation of XML file from DAX, without using AIF
Источник: http://paruvella.spaces.live.com/Blo...4DB0!496.entry
In some scenario’s, we have to generate the XML files, according to client requirements (i.e. XML files according to client schema definition).
In this case the following job will help us. (Ax Job for this example placed at the following path).
http://cid-f2ec589e221a4db0.skydrive.live.com/self.aspx/.Public/Generate%20XML%20file%5EJ%20without%20AIF/Job%5E_PSCreateXMLPO%5E_Order.xpo
AIF - xml file drop Damon DAX in English 2 12.01.2010 13:29
Dave: AIF Configuration and Additional Findings Blog bot DAX Blogs 1 04.11.2009 17:29
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
axStart: InfoPath with default AIF file inbound offline Blog bot DAX Blogs 0 20.05.2008 19:05
Dave: XML File Size limitation using FindList AIF Actions Blog bot DAX Blogs 0 12.04.2007 16:10
Часовой пояс GMT +3, время: 09:51.
