Старый 10.03.2010, 01:05   #1
mscrmblog: SP - Uploading files to SharePoint document library
Источник: http://mscrmblog.net/2010/03/09/sp-u...ument-library/
here we go, just some simple upload code that uploads documents into a document library.
It also checks if the same file exist in the destination library before upload.
SPSite site = new SPSite("http://mysharepointsite");SPWeb web = site.OpenWeb();web.AllowUnsafeUpdates = true; // i always add this in to prevent security errorsStream fStream = postedFile.InputStream;byte[] contents = new byte[fStream.Length];fStream.Read(contents, 0, (int)fStream.Length);fStream.Close();string newFilename = System.IO.Path.GetFileName(postedFile.FileName);SPFile fileExist = web.GetFile(destFolder + "/" + newFilename);if (fileExist.Exists){ Response.Write("Error: A file exist with the same filename. Please Rename this File.
");}else{ web.GetFolder(destFolder).Files.Add(newFilename, contents); completed.Text = "
Successfully uploaded '" + filename + "' to: " + destFolder + "
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Muhammad Ali Khan: Using Business Connectivity Services(BCS) In SharePoint 2010 For Connecting To MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 25.01.2010 01:08
Muhammad Ali Khan: Business Connectivity Services (BCS) Using WCF & SharePoint Designer 2010 Blog bot Dynamics CRM: Blogs 0 12.01.2010 04:44
Solutions Monkey: Accessing SharePoint Document Library through UNC Path. Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 11:11.
