Старый 12.02.2010, 02:17   #1
Development Hole: A custom rendering template for the Calendar View control
Источник: http://geek.hubkey.com/2010/02/custo...-calendar.html
Q: How do I create a custom rendering template that only affects one calendar view on the site?
A: In Microsoft Office SharePoint Server 2007 and WSS 3.0 it is possible to use a custom view style with the SPCalendarView control, so that additional views or replacements for the default views (Day, Week, Month) can be rendered by a custom RenderingTemplate.
This functionality is provided by using the undocumented SPCustomViewElement element definition, which may be used to create a custom view feature at the web level, that it turn points to the custom rendering template, e.g.:
Although this functionality is native to MOSS and WSS 3.0, the definition for SPCustomViewElement may have been omitted from the wss.xsd schema. If this type is missing from the TEMPLATE\XML\wss.xsd file, the addition of a solution with the CustomView element will fail when verified against the schema. To avoid this scenario, the following type definition (highlighted in turquqoise) must be included in the wss schema file. Please note that editing the wss schema file cannot be recommended, please contact your Microsoft representative for more information.
The custom rendering template shown below is copied from the CalendarViewweekChrome template. Use DefaultTabsEnabled=false (highlighted in turquqoise) to replace the default calendar view tabs.
The CalendarViewStyles element in the view’s Schema Xml can be used to set the default view, e.g.:
mscrmblog: Customize Marketing List (List Member View) Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Development Hole: NAICS Code Lookup - SIC Code Finder for Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 17:13.
