Старый 20.10.2009, 19:05   #1
CRM Programmer: MS CRM Fetch and Retrieve from javascript
Источник: http://crmpro.blogspot.com/2009/10/m...ieve-from.html
This code snippet was writing exactly like recommended in MSCRM SDK 4.09.
I was put it in OnLoad() event of my account form, and in the lookup field(at my example - new_postalcodeid) at OnChange() event I was calling my function.
There is two function that are doing the same work but with different methods.
var authenticationHeader = GenerateAuthenticationHeader();
crmForm.all.address1_city.ForceSubmit = true;
window.GetRegionByIndex_Retrieve = function()
if (crmForm.all.new_postalcodeid.DataValue == null)
crmForm.all.address1_city.Disabled = false;
crmForm.all.address1_city.DataValue = "";
return;
var lookupItem = new Array;
lookupItem = crmForm.all.new_postalcodeid.DataValue;
if(lookupItem[0] != null)
// Prepare the SOAP message.
var xml = ""+
authenticationHeader+
"new_postalcode"+
""+lookupItem[0].id+""+
"new_regcityarea"+
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Display the retrieved value.
else
crmForm.all.address1_city.DataValue = resultXml.selectSingleNode("//q1:new_regcityarea").nodeTypedValue;
crmForm.all.address1_city.Disabled = true;
window.GetRegionByIndex_Fetch = function (){
return;
var xml = "" +
authenticationHeader +
"<fetch mapping='logical'>" +
"<entity name='new_postalcode'>" +
"<attribute name='new_postalcodeid'/>"+
"<attribute name='new_regcityarea'/>"+
"<filter type='and'>"+
"<condition attribute='new_postalcodeid' operator='eq' value='"+lookupItem[0].id+"'/>"+
"</filter></entity></fetch>" +
var xmlHttpRequest = new ActiveXObject("Msxml2.XMLHTTP");
xmlHttpRequest.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xmlHttpRequest.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Fetch");
xmlHttpRequest.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xmlHttpRequest.setRequestHeader("Content-Length", xml.length);
xmlHttpRequest.send(xml);
var resultXml = xmlHttpRequest.responseXML;
alert(msg);
// Process and display the results.
else
// Capture the result and UnEncode it.
var resultSet = new String();
resultSet = resultXml.text;
resultSet.replace('<','');
var xmlDoc = new ActiveXObject("Microsoft.XMLDOM");
xmlDoc.async = false;
xmlDoc.loadXML(resultSet);
var results = xmlDoc.getElementsByTagName('result');
for(i=0;i
CRM Programmer: How to retrieve from many-to-many entity. Blog bot Dynamics CRM: Blogs 0 13.10.2009 19:06
Microsoft Dynamics CRM Team Blog: Linked Entity Column Data in Advanced Find Blog bot Dynamics CRM: Blogs 0 22.01.2009 05:06
mscrm4ever: CRM 4.0 Supported Multi Select (Picklist) Control Blog bot Dynamics CRM: Blogs 0 25.12.2008 15:05
Часовой пояс GMT +3, время: 04:42.
