Старый 07.09.2009, 13:05   #1
Afna CRM: Link to custom entity – use of etn instead of etc argument
Источник: http://a-crm.blogspot.com/2009/09/li...se-of-etn.html
If you want to create a direct link to an out-of-a-box entity it is a very simple task: Right-click on one instance (let’s say account) and select “Copy Shortcut”.
Then just just change the GUID in the URL to open desired account. For the Account this URL looks like this: http://SERVER:PORT/OrganizationName/sfa/accts/edit.aspx?id={GUID}
Custom entities
All custom entities have the same URL structure: http://SERVER:PORT/OrganizationName/userdefined/edit.aspx?id={GUID}&etc=EntityTypeCode
Notice the entity type code? This code is created when creating the entity. But for some reason Entity Type Code can be (in most cases) different on every CRM instance. This means that if you are creating a plugin that needs to create a link to the entity, you will have to query metadata to get the code or enter that code in configuration part.
But there is a better way:
Instead of “etc” argument you can use “etn” (Entity Name) in the query string. The use the logical name of the entity. Logical name is the same on all instances.
http://SERVER:PORT/OrganizationName/userdefined/edit.aspx?id={GUID}&etn=EntityName
http://testsrv:5555/Contoso/userdefined/edit.aspx?id={08B91EBF-525A-DE11-94A6-002354F5ABA2}&etn=new_testentity
Afna CRM: Show custom notifications on Microsoft Dynamics CRM - upgrade Blog bot Dynamics CRM: Blogs 0 10.08.2009 18:05
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 19:25.
