Старый 02.09.2009, 10:05   #1
CRM DE LA CREME! Some useful CRMform jscripts
Источник: http://crmdelacreme.blogspot.com/200...-jscripts.html
<span style="font-family:arial;font-size:85%;">/*
function isFormInCreateMode()
function isFormInUpdateMode()
isFormActive = function()
hideNavBarItemById = function(navBarItemId)
setNavBarItemVisibilityByName = function(sectionName, itemName, visible)
hideNavBarItemByName = function(sectionName, itemName)
showNavBarItemByName = function(sectionName, itemName)
setFormEnabled = function(enabled)
hideTabById = function(tabId)
hideTabByName = function(tabName)
setControlEnabled = function(fieldObject, enabled)
setFieldRequired = function(fieldObject)
setFieldRecommended = function(fieldObject)
setFieldNotRequired = function(fieldObject)
refParam = function()
getLastKnownGood = function(fieldObject)
setLastKnownGood = function(fieldObject, value)
captureLastKnownGood = function(fieldObject)
restoreLastKnownGood = function(fieldObject)
hookValidationOnChange = function(fieldObject)
hookValidationOnBlur = function(fieldObject)
hookValidation = function(fieldObject, functionPointer, optionalFocusFieldObject)
performValidation = function()
function guidString4()
createGuid = function()
hideActionMenuItem = function(itemName)
HideAssociatedViewButtons = function(loadAreaId, buttonTitles)
// Check if form in CREATE mode
isFormInCreateMode = function()
if (crmForm.FormType == 1)
return true;
else
return false;
// Check if form in UPDATE mode
isFormInUpdateMode = function()
if (crmForm.FormType == 2)
return true;
else
return false;
var active = true;
if (crmForm.all.statecode != null && crmForm.all.statecode.DataValue != null )
active = (crmForm.all.statecode.DataValue == 0);
if( active )
active = (crmForm.FormType 4); // not readonly or disabled
return active;
/* Navigation Map Functions
/* hide a navigation bar item */
var navBar = document.getElementById(navBarItemId)
if (navBar != null)
navBar.style.display = "none";
/* hide a tab using the tab name as reference */
setNavBarSectionVisibilityByName = function( sectionName, visible )
var groups = document.getElementById("crmNavBar").childNodes;
if( groups != null )
for( var i = 0; i < groups.length; i++ )
var groupName = groups[i].childNodes[0];
if( groupName.innerText.trim() == sectionName )
groupName.style.display = visible ? "block" : "none";
groups[i].childNodes[1].style.display = visible ? "block" : "none";
setNavBarItemVisibilityByName = function( sectionName, itemName, visible )
var items = groups[i].childNodes[1].childNodes;
for( var n = 0; n < items.length; n++ )
var item = items[n];
if( item.innerText.trim() == itemName )
item.style.display = visible ? "inline" : "none";
hideNavBarItemByName = function( sectionName, itemName )
setNavBarItemVisibilityByName(sectionName, itemName, false);
showNavBarItemByName = function( sectionName, itemName )
setNavBarItemVisibilityByName(sectionName, itemName, true);
/* Form Functions
var iLen = crmForm.all.length;
for (i = 0; i < iLen; i++)
crmForm.all[i].Disabled = !enabled;
// gets the ordinal position of a tab
getTabNumber = function( tabName ) {
var tabs = document.getElementById("crmTabBar").childNodes;
if( tabs != null ) {
for (var i = 0; i < tabs.length; i++) {
var tab = tabs[i];
if (tab.innerText == tabName) {
return i;
return -1;
// returns a tab by name
getTabByName = function( tabName ) {
if (tabs != null) {
var num = getTabNumber(tabName);
if( num >= 0 ) {
return tabs[num];
return null;
/* disable or enable tab using the tab name as reference */
setTabEnabledByName = function(tabName, enabled)
var tab = getTabByName(tabName);
if( tab != null ) {
tab.disabled = !enabled;
/* hide a tab using the tab id as reference */
var tab = document.getElementById(tabId);
if( tab != null ) {
tab.style.display = "none";
if( tab != null ) {
//alert(tab.style.display);
/* show a tab using the tab name as reference */
showTabByName = function(tabName)
if( tab != null ) {
tab.style.display = "block";
/* Enabled/disable a control by setting the disabled property and toggling "ms-crm-ReadOnly" on the classname */
fieldObject.disabled = !enabled;
if (!enabled && fieldObject.className.indexOf("ms-crm-Text") >= 0) {
// append readonly property to className if not already there
if (fieldObject.className.indexOf("ms-crm-ReadOnly") < 0)
fieldObject.className += " ms-crm-ReadOnly";
else
fieldObject.className = fieldObject.className.replace(/ ms-crm-ReadOnly/gi, "");
crmForm.SetFieldReqLevel(fieldObject.id, 2);
crmForm.SetFieldReqLevel(fieldObject.id, 1);
crmForm.SetFieldReqLevel(fieldObject.id, 0);
/* Validation base functions
/* represents a parameter object to be passed by reference
* use param.setValue from a function to set the return value of the parameter
* use param.getValue to read the returned value
this.array = new Array(1);
this.setValue = function(v) { this.array[0] = v; }
this.getValue = function() { return this.array[0]; }
/* gets/captures/restores the value of the field as the last known good value */
return fieldObject.getAttribute("lastKnownGood");
fieldObject.setAttribute("lastKnownGood", value);
setLastKnownGood(fieldObject, fieldObject.DataValue);
fieldObject.DataValue = getLastKnownGood(fieldObject);
* captures last known good value (captureLastKnownGood)
* hooks validation of the field onto the "onchange" event
fieldObject.setAttribute("onblur", null);
fieldObject.setAttribute("onchange", performValidation);
fieldObject.setAttribute("onchange", null);
fieldObject.setAttribute("onblur", performValidation);
captureLastKnownGood(fieldObject);
fieldObject.setAttribute("validationFunction", functionPointer);
if( optionalFocusFieldObject != null )
fieldObject.setAttribute("focusFieldObject", optionalFocusFieldObject);
var fieldObject = event.srcElement;
if( fieldObject.DataValue != getLastKnownGood(fieldObject) )
var functionPointer = fieldObject.getAttribute("validationFunction");
var message = new refParam();
var valid = functionPointer(fieldObject, message);
if( !valid )
var msg = message.getValue() + "\r\n\nWould you like to correct the value?";
if( confirm(msg) )
var focusObject = fieldObject.getAttribute("focusFieldObject");
if( focusObject == null )
focusObject = fieldObject;
else
hookValidationOnChange(fieldObject);
setLastKnownGood(focusObject, null);
focusObject.SetFocus();
event.returnValue = false;
hookValidationOnBlur(focusObject);
else
restoreLastKnownGood(fieldObject);
else
else
guidString4 = function()
return (((1 + Math.random()) * 0x10000) 0).toString(16).substring(1);
return (guidString4() + guidString4() + "-" + guidString4() + "-" + guidString4() + "-" + guidString4() + "-" + guidString4() + guidString4() + guidString4()).toUpperCase();
/* hide action menu item */
var element = document.getElementById(itemName)
if (element != null) {
element.style.display = "none";
hideActionMenuDeleteButton = function()
hideActionMenuItem("_MIonActionMenuClickdelete" + crmForm.ObjectTypeCode);
hideActionMenuDeactivateButton = function()
hideActionMenuItem("_MIchangeStatedeactivate" + crmForm.ObjectTypeCode + "5");
hideActionMenuActivateButton = function()
hideActionMenuItem("_MIchangeStateactivate" + crmForm.ObjectTypeCode + "6");
/* Hides the associated Views buttons. i.e Hides the add existing button. */
/* NB: If called multiple times, the settings of the previous calls are overwritten by the final one! */
/* A menu element on the "More actions" drop-down menu can be hidden
* by adding a string such as 'More Actions::Activate' to the buttonTitles array.
var navElement = document.getElementById('nav_' + loadAreaId);
if (navElement != null)
navElement.onclick = function LoadAreaOverride()
// Call the original CRM method to launch the navigation link and create area iFrame
loadArea(loadAreaId);
HideViewButtons(document.getElementById(loadAreaId + 'Frame'), buttonTitles);
/* Used internally by the 'HideAssociatedViewButtons' method */
HideViewButtons = function(Iframe, buttonTitles)
if (Iframe != null)
Iframe.onreadystatechange = function HideTitledButtons()
if (Iframe.readyState == 'complete')
var iFrame = frames[window.event.srcElement.id];
var liElements = iFrame.document.getElementsByTagName('li');
for (var j = 0; j < buttonTitles.length; j++)
buttonTitleParts = buttonTitles[j].split('::');
if (buttonTitleParts.length > 0)
buttonTitle = buttonTitleParts[0];
for (var i = 0; i < liElements.length; i++)
liElement = liElements[i];
if (liElement.getAttribute('title') == buttonTitle)
if (buttonTitleParts.length == 1)
liElement.style.display = 'none';
break;
else
/* We want to hide a menu item in a drop-down menu.
Find the descendant text element with the specified text.
Then find its parent list item and hide it:
menuText = buttonTitleParts[1];
var spanElements = liElement.getElementsByTagName('span');
for (var k = 0; k < spanElements.length; k++)
spanElement = spanElements[k];
if (spanElement.className == 'ms-crm-MenuItem-Text' )
textElement = spanElement.firstChild;
if (textElement != null && textElement.nodeType == 3) /* 3 = Node.TEXT_NODE */
if (textElement.data == menuText)
liMenuItemElement
= spanElement.parentNode.parentNode.parentNode;
liMenuItemElement.style.display = 'none';
break;
// Load up a CRM entity into an iframe - typically the main view screen
getCRMFormSource = function(tabSet)
if (crmForm.ObjectId != null)
var oId = crmForm.ObjectId;
var oType = crmForm.ObjectTypeCode;
var security = crmFormSubmit.crmFormSubmitSecurity.value;
return "/userdefined/areas.aspx?oId=" + oId + "&oType=" + oType + "&security=" + security + "&tabSet=" + tabSet;
else
return "about:blank";
setVisibilityOfSectionContainingField = function(crmField, visibility)
if (visibility)
crmField.parentElement.parentElement.parentElement.style.display = 'block';
else
crmField.parentElement.parentElement.parentElement.style.display = 'none';
hideSectionContainingField = function(crmField)
setVisibilityOfSectionContainingField(crmField, false);
setVisibilityOfSectionWithName = function(tabNumber, sectionName, visibility)
var tab = document.getElementById('tab' + tabNumber.toString());
if (tab != null)
var tdElements = tab.getElementsByTagName('td');
for (var i = 0; i < tdElements.length; i++)
tdElement = tdElements[i];
if (tdElement.className == 'ms-crm-Form-Section ms-crm-Form-SectionBar')
textElement = tdElement.firstChild;
if (textElement.data == sectionName)
trSectionElement
= tdElement.parentNode.parentNode.parentNode.parentNode.parentNode;
if (visibility)
trSectionElement.style.display = 'block';
else
trSectionElement.style.display = 'none';
return true;
return false;
hideSectionWithName = function(tabNumber, sectionName)
return setVisibilityOfSectionWithName(tabNumber, sectionName, false);
hideSection = function(tabName, sectionName) {
var tabNumber = getTabNumber(tabName);
showSection = function(tabName, sectionName) {
return setVisibilityOfSectionWithName(tabNumber, sectionName, true);
showModalWindow = function(url, objectparams, x, y, height, width)
return window.showModalDialog(url, objectparams,
(height != null ? "dialogHeight:" + height.toString() + "px;" : "") +
(width != null ? "dialogWidth:" + width.toString() + "px;" : "") +
(y != null ? "dialogTop:" + y.toString() + "px;" : "") +
(x != null ? "dialogLeft:" + x.toString() + "px;" : "") +
"center:Yes;" +
"help:No;" +
"resizable:No;" +
"scroll:No;" +
"status:No;");
FetchViewer = function( iframeId )
var Instance = this;
var vDynamicForm;
var m_iframeTab;
var m_iframeDoc;
Instance.Entity = "";
Instance.Iframe = null;
Instance.FetchXml = "";
Instance.QueryId = "";
Instance.LayoutXml = "";
Instance.RegisterOnTab = function( tabIndex )
Instance.Iframe = document.getElementById( iframeId );
if( !Instance.Iframe )
return alert( "Iframe " + iframeId + " is undefined" );
m_iframeDoc = getIframeDocument();
var loadingGifHTML = "";
loadingGifHTML += "";
loadingGifHTML += "Loading View...";
m_iframeDoc.body.innerHTML = loadingGifHTML;
if( parseInt( "0" + tabIndex ) == 0 ) Instance.Refresh();
else Instance.Iframe.attachEvent( "onreadystatechange" , RefreshOnReadyStateChange );
function RefreshOnReadyStateChange()
if( Instance.Iframe.readyState != 'complete' )
return;
Instance.Refresh();
Instance.Refresh = function()
Instance.Iframe.detachEvent( "onreadystatechange" , RefreshOnReadyStateChange );
var create = m_iframeDoc.createElement;
var append1 = m_iframeDoc.appendChild;
vDynamicForm = create("");
var append2 = vDynamicForm.appendChild;
append2(create(""));
append1( vDynamicForm );
vDynamicForm.action = prependOrgName("/AdvancedFind/fetchData.aspx");
vDynamicForm.FetchXml.value = Instance.FetchXml;
vDynamicForm.LayoutXml.value = Instance.LayoutXml;
vDynamicForm.EntityName.value = Instance.Entity;
vDynamicForm.DefaultAdvFindViewId.value = Instance.QueryId;
vDynamicForm.ViewType.value = 1039;
vDynamicForm.submit();
Instance.Iframe.attachEvent( "onreadystatechange" , OnViewReady );
function OnViewReady()
if( Instance.Iframe.readyState != 'complete' ) return;
Instance.Iframe.style.border = 0;
Instance.Iframe.detachEvent( "onreadystatechange" , OnViewReady );
m_iframeDoc.body.scroll = "no";
m_iframeDoc.body.style.padding = "0px";
getIframeDocument = function()
return Instance.Iframe.contentWindow.document;
// Set custom form title
setFormTitle = function(title)
document.all.crmMenuBar.nextSibling.rows[0].cells[1].childNodes[0].innerText = title;
setLookupEnabled = function(control, enabled)
control.Disabled = !enabled;
/****************** BUTTONS *************************/
// Get an element in a document by it's class name
// Parameters:
// oElm = starting element
// strTagName = tags to filter on, e.g. TR or * for all
// oClassNames = arraylist of class names to find
// Returns:
// array of elements found
function getElementsByClassName(oElm, strTagName, oClassNames){
var arrElements = (strTagName == "*" && oElm.all)? oElm.all : oElm.getElementsByTagName(strTagName);
var arrReturnElements = new Array();
var arrRegExpClassNames = new Array();
if(typeof oClassNames == "object"){
for(var i=0; i
CRM DE LA CREME! Update Rollup 6 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 29.08.2009 11:05
CRM DE LA CREME! CRM integration into Skydrive Blog bot Dynamics CRM: Blogs 0 21.08.2009 11:05
CRM DE LA CREME! Microsoft CRM 4.0 Update Rollup Best Practices Blog bot Dynamics CRM: Blogs 0 18.08.2009 11:05
CRM DE LA CREME! Three Top Tips for CRM 4.0 Plugin Development Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 21:19.
