#1 |
Dynamics Mobile: Configuring Permissions For Processing Mobile Documents in Microsoft NAV 2009
Источник: http://blogs.msdn.com/dynamicsmobile...-nav-2009.aspx
============== For a mobile document to process from the mobile document service to Microsoft Dynamics 2009, there are several permission settings in Microsoft Dynamics 2009 that you must configure. The permission settings vary depending on whether the mobile document service communicates with Microsoft Dynamics 2009 through an Application Server or a Web Service. Note: For Microsoft Dynamics Mobile 1.5, the required permissions when using Application Server have changed from Microsoft Dynamics Mobile 1.1 and earlier versions. Using Application Server To process a mobile document in Microsoft Dynamics NAV 2009 through an Application Server, you must set up permissions in Microsoft Dynamics NAV 2009 on the following accounts:
The following table includes the set up that is required for each account in Microsoft Dynamics NAV 2009 to process a mobile document. Microsoft Dynamics NAV 2009 setupMobile user Windows accountDocument Service application pool identityApplication Server logon accountWindows loginyesyesyesRoles on the Windows loginThe roles that give permission to process information in the request document. For example, if you have a document type that creates customers, then the user’s Windows Login must be assigned the S&R-CUSTOMER, EDIT role, which is the standard role for users who have permission to create, modify, and delete customers.MOB-SERVER-NASMOB-SERVER-NAS ALL Role of each document type that Microsoft Dynamics NAV Application Server processes. Mobile UseryesyesnoAssigned to the document typeyesnonoUsing Web Services To process a mobile request document in Microsoft Dynamics NAV 2009 using Web services, you must set up permissions in Microsoft Dynamics NAV 2009 for the following accounts:
The following table includes the set up that is required for each account in Microsoft Dynamics NAV 2009 to process a mobile document. Microsoft Dynamics NAV 2009 setupMobile user Windows accountDocument handler's identityWindows loginyesyesRoles on the Windows loginThe roles that give permission to process information in the request document. For example, if you have a document type that creates customers, then the user’s Windows Login must be assigned the S&R-CUSTOMER, EDIT role, which is the standard role for users who have permission to create, modify, and delete customers.noneMobile UseryesyesAssigned to the document typeyesno Источник: http://blogs.msdn.com/dynamicsmobile...-nav-2009.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
