Старый 01.06.2009, 18:07   #1
Kipetcoff is offline
Kipetcoff
Новый Task
Пытаюсь создать новый тас программно в новом приложении,помещенном в C:\Program Files\Microsoft Dynamics CRM Server\CRMWeb\ISV.
код добавления..
Код:
CrmAuthenticationToken token = new CrmAuthenticationToken();
			token.OrganizationName = sOrgname;
			token.AuthenticationType = 0;
			//Create the Service
			CrmService crmService = new CrmService();
			crmService.Credentials = System.Net.CredentialCache.DefaultCredentials;
			//crmService.Credentials = new System.Net.NetworkCredential("administrator", "pass@word1", "LITWAREINC");
			crmService.CrmAuthenticationTokenValue = token;
			string crmurl = (string)(Registry.LocalMachine.OpenSubKey("Software\\Microsoft\\MSCRM").GetValue("ServerUrl")) + "/2007/crmservice.asmx";
			crmService.Url = crmurl;
            string sType = string.Empty;
            string sId = string.Empty;
            if(Request.Params["typename"]!=null)
              sType = Request.Params["typename"];
			  sId = Request.Params["id"];
			  txtNotes.Text = "sType-" + sType;
			  txtNotes.Text += "sId-" + sId;
			  Microsoft.Crm.Sdk.Query.ColumnSet cols = new Microsoft.Crm.Sdk.Query.ColumnSet();
			  //cols.Attributes = new ArrayList();
			  cols.Attributes.Add("subject");
			  Guid gId = new Guid(sId);
			  lead oLead = (lead)crmService.Retrieve(sType, gId, cols);
			  txtNotes.Text += "oLead.subject-" + oLead.subject;
			  string ssubject = oLead.subject;
			  task t = new task();
			  //t.prioritycode = new PickList();
			  //t.prioritycode.Value = Convert.ToInt32("0");
			  t.subject = "my first task";
			  t.description = "my first task description";
			  t.scheduledstart = new CrmDateTime();
			  t.scheduledstart.Value = DateTime.Now.ToString();
			  t.scheduledend = new CrmDateTime();
			  t.scheduledend.Value = DateTime.Now.ToString();
			  t.regardingobjectid = new Lookup();
			  //t.regardingobjectid.name = "my name";
			  t.regardingobjectid.type = EntityName.lead.ToString();
			  t.regardingobjectid.Value = gId;
			  //t.ownerid = new Owner();
			  //t.ownerid.name = "my name";
			  //t.ownerid.type = "type of object";
			  //t.ownerid.Value = new Guid();
			  t.scheduleddurationminutes = new CrmNumber();
			  t.scheduleddurationminutes.Value = 45;
			  Guid gTSKId=new Guid();
			  try
				  gTSKId = crmService.Create(t);
			  catch (System.Web.Services.Protocols.SoapException ex)
				  txtNotes.Text += ex.Detail.InnerText;
			  txtNotes.Text+=  "gTSKId-" + gTSKId.ToString();
			  if(gTSKId!=Guid.Empty)
				  SetStateTaskRequest tr = new SetStateTaskRequest();
				  tr.EntityId = gTSKId;
				  tr.TaskState = new TaskState();
				  tr.TaskState = TaskState.Completed; //(or Canceled,Open);
				  tr.TaskStatus = -1; //(set this to -1 so that CRM can decide the appropriate status.)
				  crmService.Execute(tr);
Так вот на все это безобразие ругается 0x80044150 Generic SQL error. Гугл на это выдает много разного,но чаще всего э то касается ошибки при бобавлении e-mail activities. Я же добавляю таск. Я вычитал что можно где-то посмотреть eventview. У самого сервера в ивентах ничего нет по этой ошибке. Где ивенты та смотерть? Может я просто что-то не то определил. Активити у меня определяется для leads. Я правльно привязываю их к leads?
Единственный толковый ресурс откуда я в общем-то и взял весь код это http://mymscrm3.blogspot.com/2007/12...in-crm-30.html
Старый 02.06.2009, 12:58   #2
BSvetlana is offline
BSvetlana
Вот мой вариант. Может, почерпнете что-нибудь из этого
string orgName = Request.QueryString["orgname"];
ViewState["orgname"] = orgName;
token.OrganizationName = orgName;
CrmService service = new CrmService();
service.CrmAuthenticationTokenValue = token;
service.Credentials = System.Net.CredentialCache.DefaultCredentials;
Guid userid = new Guid();
WhoAmIRequest userRequest = new WhoAmIRequest();
WhoAmIResponse currentUser = (WhoAmIResponse)service.Execute(userRequest);
userid = currentUser.UserId;
task task = new task();
//string correctDateTime = "2009-05-08T12:00:00";
string correctDateTime = "";
string year = idDate.Text.Substring(6, 4);
string month = idDate.Text.Substring(3, 2);
string day = idDate.Text.Substring(0, 2);
// Set the task subject.
task.subject = subjectText.Text;
string time = idTime.SelectedItem.Text;
string hour = "";
string minute = "";
hour = time.Substring(0, 2);
minute = time.Substring(3, 2);
// Set the date of the task.
correctDateTime = year + "-" + month + "-" + day + "T" + hour + ":" + minute + ":00";
task.scheduledstart = new CrmDateTime();
task.scheduledstart.Value = correctDateTime;
//Set the regardingobject
task.regardingobjectid = new Lookup();
task.regardingobjectid.Value = new Guid(regardingobjectidHidden.Value);
task.regardingobjectid.type = EntityName.account.ToString();
//Set the user
task.ownerid = new Owner();
task.ownerid.Value = user.UserId;
task.ownerid.type = EntityName.systemuser.ToString();
if (descriptionText.Text != "")
task.description = descriptionText.Text;
//Try to create the task
Guid createdTaskId = service.Create(task);
#region check success
Boolean success = false;
if (createdTaskId != Guid.Empty)
success = true;
Log("Task success " + success);
Что-то вроде.....
Старый 02.06.2009, 15:10   #3
Kipetcoff
Что-то не помогает..все то же самое... 0x80044150 Generic SQL erro
Старый 02.06.2009, 16:10   #4
Kipetcoff
Решил покопаться с помощью sql profiler. поочередно запускал все действия во время работы программы. Единственное что не сработало это
"exec sp_executesql N'insert into QueueItemBase(QueueId, OrganizationId, State, Status, ObjectId, ModifiedOn, Priority, CreatedBy, ObjectTypeCode, TimeZoneRuleVersionNumber, EnteredOn, Title, ModifiedBy, QueueItemId, DeletionStateCode, CreatedOn, UTCConversionTimeZoneCode) values (@QueueId0, @OrganizationId0, @State0, @Status0, @ObjectId0, @ModifiedOn0, @Priority0, @CreatedBy0, @ObjectTypeCode0, @TimeZoneRuleVersionNumber0, @EnteredOn0, @Title0, @ModifiedBy0, @QueueItemId0, @DeletionStateCode0, @CreatedOn0, @UTCConversionTimeZoneCode0)',N'@QueueId0 uniqueidentifier,@OrganizationId0 uniqueidentifier,@State0 int,@Status0 int,@ObjectId0 uniqueidentifier,@ModifiedOn0 datetime,@Priority0 int,@CreatedBy0 uniqueidentifier,@ObjectTypeCode0 int,@TimeZoneRuleVersionNumber0 int,@EnteredOn0 datetime,@Title0 ntext,@ModifiedBy0 uniqueidentifier,@QueueItemId0 uniqueidentifier,@DeletionStateCode0 int,@CreatedOn0 datetime,@UTCConversionTimeZoneCode0 int',@QueueId0='00000000-0000-0000-0000-000000000000',@OrganizationId0='00B573ED-1D22-4EF7-8DB1-6016CAA1EB35',@State0=0,@Status0=2,@ObjectId0='50F7396A-6B4F-DE11-84BC-0003FF94D69B',@ModifiedOn0='2009-06-02 11:49:24:000',@Priority0=1,@CreatedBy0='D874E288-2C8C-43D5-AEBA-5404888BC185',@ObjectTypeCode0=4212,@TimeZoneRuleVersionNumber0=0,@EnteredOn0='2009-06-02 11:49:24:000',@Title0=N'subjectText.Text',@ModifiedBy0='D874E288-2C8C-43D5-AEBA-5404888BC185',@QueueItemId0='51F7396A-6B4F-DE11-84BC-0003FF94D69B',@DeletionStateCode0=0,@CreatedOn0='2009-06-02 11:49:24:000',@UTCConversionTimeZoneCode0=0
Ошибка на все это "Msg 547, Level 16, State 0, Line 1
The INSERT statement conflicted with the FOREIGN KEY constraint "queue_entries". The conflict occurred in database "MicrosoftCRM_MSCRM", table "dbo.QueueBase", column 'QueueId'.
The statement has been terminated."
Где можно трассировку посомтреть в CRM?
Старый 02.06.2009, 17:23   #5
Kipetcoff
В трассировке именно то что я в SQL нашел... "System.Data.SqlClient.SqlException: The INSERT statement conflicted with the FOREIGN KEY constraint "queue_entries". The conflict occurred in database "MicrosoftCRM_MSCRM", table "dbo.QueueBase", column 'QueueId'."
Старый 02.06.2009, 18:15   #6
Kipetcoff
Заработало..я поменял код создания сервиса
Код:
			//crmService.Credentials = System.Net.CredentialCache.DefaultCredentials;
			crmService.Credentials = new System.Net.NetworkCredential("administrator", "pass@word1");
			crmService.PreAuthenticate = false;
Старый 02.06.2009, 18:45   #7
Kipetcoff
Почему-то не работает код crmService.Credentials = System.Net.CredentialCache.DefaultCredentials; Хотя в моем приложениие есть
<authentication mode="Windows"/>
<identity impersonate="true"/>
Что такое происходит?
Старый 03.06.2009, 00:33   #8
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Сообщение от Kipetcoff Посмотреть сообщение
<authentication mode="Windows"/> это уберите.
Плюс всю работу с CrmService оберните конструкцией using (new CrmImpersonator()){...}
Старый 03.06.2009, 10:44   #9
Kipetcoff
Спасибо, помогло!!!
Старый 08.06.2009, 11:21   #10
Kipetcoff
К сожалению все таки не работает DefaultCredentials. Я что-то упустил и подумал что настройки конфига сработали. На самом деле как работало через crmService.Credentials = new System.Net.NetworkCredential("administrator", "pass@word1"); так и работает. Есть какой-нить другой способ передать информацию о пользователе св-ву crmService.Credentials? Почему у всех людей работает а у меня нет? Конфиг приложил......
Код сохранения
Код:
protected void btnSave_Click(object sender, Coolite.Ext.Web.AjaxEventArgs e)
		if (ValidateActivityDate())
			string sOrgname = string.Empty;
			sOrgname = Request.Params["orgname"];
			//crmService.Credentials = new System.Net.NetworkCredential("administrator", "pass@word1");
			//crmService.Credentials = WindowsIdentity.GetCurrent();
			crmService.Url = (string)(Registry.LocalMachine.OpenSubKey("Software\\Microsoft\\MSCRM").GetValue("ServerUrl")) + "/2007/crmservice.asmx";
			string sLeadId = string.Empty;
			if (Request.Params["typename"] != null && Request.Params["id"] != null)
				sLeadId = Request.Params["id"];
				Guid gLeadId = new Guid(sLeadId);
				lead oLead = (lead)crmService.Retrieve(sType, gLeadId, cols);
				WhoAmIResponse currentUser = (WhoAmIResponse)crmService.Execute(userRequest);
				task.subject = txtNotes.Text;
				task.scheduledstart.Value = txtActivity.SelectedDate.ToString("s");
				task.actualdurationminutes = new CrmNumber();
				task.actualdurationminutes.Value = Convert.ToInt32(ddDuration.SelectedItem.Value);
				task.regardingobjectid.Value = oLead.leadid.Value;
				task.regardingobjectid.type = EntityName.lead.ToString();
				//Set the user
				task.ownerid.Value = userid;
				//set created by
				task.createdby = new Lookup();
				task.createdby.Value = userid;
				task.createdby.type = EntityName.systemuser.ToString();
				Guid gTSKId = new Guid();
				try
					gTSKId = crmService.Create(task);
					lblError.Text = string.Empty;
					lblInfo.Text = "\"" + task.subject + "\" Task Added.";
					lblInfo.Text = string.Empty;
					lblError.Text += ex.Detail.InnerText + userid.ToString() + " " + sOrgname;
Тип файла: txt Web.config.txt (6.5 Кб, 296 просмотров)
Последний раз редактировалось Kipetcoff; 08.06.2009 в 12:34.
Старый 08.06.2009, 15:15   #11
Kipetcoff
Опытным путем выяснил что причина в конфликте конструкций using (new CrmImpersonator()) и try catch. Нужно использовать или то или другое. Осталось только понять почему так..
Новый пользователь из другого домена if_maks Dynamics CRM: Администрирование 27 11.11.2009 14:54
Как лучше реализовать? Создать новый объект или... Sederick Dynamics CRM: Функционал 12 08.04.2009 14:04
Plugin на для обновления задачи (Task) Bondonello Dynamics CRM: Разработка 14 25.02.2009 12:13
связь через новый объект valk Dynamics CRM: Разработка 3 07.12.2007 08:56
связь через новый объект valk Dynamics CRM: Разработка 0 06.12.2007 12:09
Часовой пояс GMT +3, время: 02:19.
