Старый 26.05.2009, 17:05   #1
mscrm4ever: CRM 4.0 Multi Lingual Support in Plug-ins
Источник: http://mscrm4ever.blogspot.com/2009/...t-in-plug.html
The following code presents a simple yet very effective way to handle and return multi-lingual error messages form a plug-in.
So how does it work?
Basically I created a base class for Custom Exceptions. All custom exceptions that you use in your code derive from this class. The base class overrides the Exception class Message property and returns the error message from a resources dictionary.
The resource dictionary holds the translations for each local id e.g. (1033, 3082). When an exception is thrown the user local id (LCID) is taken from the current running thread Culture Info object.
The Inner translation dictionary manages the each error message depending on the exception type. This way when the code throws a specific exception the correct error message is fetched from the dictionary.
Enjoy…
using System;
using System.Collections.Generic;
using System.Text;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Crm.Sdk.Query;
using System.Web.Services.Protocols;
namespace Empty.PlugIn
public class Handler : IPlugin
#region IPlugin Members
/// Resource Dictionary
public static Dictionary Resources;
public void Execute(IPluginExecutionContext context)
if (Resources == null)
Resources = new Dictionary();
Dictionary English = new Dictionary();
English.Add(typeof(Exception), "General Exception");
English.Add(typeof(SoapException), "CRM Exception");
English.Add(typeof(InvalidCustomException), "Invalid Custom Exception");
English.Add(typeof(UnKnownPluginException), "UnKnown Plugin Exception");
Resources.Add(1033, English);
Dictionary Spanish = new Dictionary();
Spanish.Add(typeof(Exception), "Excepciףn general");
Spanish.Add(typeof(SoapException), "Excepciףn de CRM");
Spanish.Add(typeof(InvalidCustomException), "Excepciףn personalizado no vבlido");
Spanish.Add(typeof(UnKnownPluginException), "Excepciףn Desconocida Plugin");
Resources.Add(3082, Spanish);
try
//throw new Exception();
//throw new SoapException();
throw new UnKnownPluginException();
catch(Exception ex)
throw new InvalidPluginExecutionException(ex.Message);
public abstract class CustomException : Exception
private Int32 DefaultLanguage = 1033;
/// override default message prop
public override string Message
get
return this.GetResource(this.GetType());
/// Get the resource by exception type
protected string GetResource(Type type)
Int32 uiLcid = System.Threading.Thread.CurrentThread.CurrentUICulture.LCID;
if (Resources.ContainsKey(uiLcid))
return Resources[uiLcid][type];
return Resources[this.DefaultLanguage][type];
public class InvalidCustomException : CustomException
public class UnKnownPluginException : CustomException
#endregion
mscrm4ever: CRM 4.0 Concatenating Fields Plug-In Blog bot Dynamics CRM: Blogs 0 14.02.2009 14:05
mscrm4ever: CRM 4.0 Creating Interactive Plug-ins Blog bot Dynamics CRM: Blogs 0 21.01.2009 10:05
mscrm4ever: CRM 4.0 Supported Multi Select (Picklist) Control Blog bot Dynamics CRM: Blogs 0 25.12.2008 15:05
Microsoft Dynamics CRM Team Blog: Part Deux: Storing Configuration Data for Microsoft Dynamics CRM Plug-ins Blog bot Dynamics CRM: Blogs 0 15.11.2008 09:07
Microsoft Dynamics CRM Team Blog: Storing Configuration Data for Microsoft Dynamics CRM Plug-ins Blog bot Dynamics CRM: Blogs 0 24.10.2008 22:05
Часовой пояс GMT +3, время: 02:47.
