Старый 17.02.2009, 10:22   #1
Kosta100 is offline
Kosta100
Проблема с установкои Email Router на CRM 4
Доброе время суток всем !
Сталкнулса с проблемои при установке Email Router на CRM 4 .
Дает такои лог :
System.Exception: Action Microsoft.Crm.Setup.Exchange.InstallServiceAction failed. ---> System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.Int32.Parse(String s, IFormatProvider provider)
at System.Diagnostics.PerformanceCounterLib.GetStringTable(Boolean isHelp)
at System.Diagnostics.PerformanceCounterLib.get_NameTable()
at System.Diagnostics.PerformanceCounterLib.get_CategoryTable()
at System.Diagnostics.PerformanceCounterLib.CategoryExists(String machine, String category)
at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName, String machineName)
at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName)
at Microsoft.Crm.Tools.Email.Agent.EmbeddedInstaller.Install(IDictionary stateSaver)
at System.Configuration.Install.Installer.Install(IDictionary stateSaver)
at System.Configuration.Install.AssemblyInstaller.Install(IDictionary savedState)
at Microsoft.Crm.Setup.Exchange.InstallServiceAction.Do(IDictionary parameters)
at Microsoft.Crm.Setup.Common.Action.ExecuteAction(Action action, IDictionary parameters, Boolean undo)
--- End of inner exception stack trace ---
at Microsoft.Crm.Setup.Common.Installer.Install(IDictionary stateSaver)
at Microsoft.Crm.Setup.Common.ComposedInstaller.InternalInstall(IDictionary stateSaver)
at Microsoft.Crm.Setup.Common.ComposedInstaller.Install(IDictionary stateSaver)
at Microsoft.Crm.Setup.Exchange.ExchangeSetup.Install(IDictionary data)
at Microsoft.Crm.Setup.Exchange.ExchangeSetup.Run()
at Microsoft.Crm.Setup.Exchange.ExchangeSetup.InternalMain(String[] args)
ExchangeInstallInfo.IsInvokedFromServerSetupProperty: False
ExchangeInstallInfo.IsUpgradeProperty: False
ExchangeInstallInfo.LaunchConfigToolProperty: True
InstallInfo.AdminTargetFolder:
InstallInfo.AllowRun: True
InstallInfo.CleanupRequired: False
InstallInfo.CreateDatabase: True
InstallInfo.CurrentFolder: C:\Documents and Settings\Administrator.DISKAL\Local Settings\Temp\1\MSCRM_{E1575DA9-116E-4EA3-8560-D6C005DE097F}
InstallInfo.InstallAlways: False
InstallInfo.InstallingPackage: Z:\Exchange\i386\Exchange.msi
InstallInfo.InstallType: Install
InstallInfo.LocalPackage:
InstallInfo.LogFile: C:\Documents and Settings\Administrator.DISKAL\Application Data\Microsoft\MSCRM\Logs\crm40Exchangesetup.log
InstallInfo.PackageName: Exchange.msi
InstallInfo.RebootRequired: False
InstallInfo.RunEdwChecks: True
InstallInfo.SharedInstall: False
InstallInfo.SourceFolder: Z:\Exchange\i386
InstallInfo.SuppressReboot: False
InstallInfo.TargetFolder: C:\Program Files\Microsoft CRM Email
InstallInfo.UIMode: Full
InstallInfo.UserCancel: False
IpcInfo.NoLock: False
ProductInfo.Features: System.Collections.Specialized.ListDictionary
ProductInfo.InstallingLanguage: 1033
ProductInfo.InstallingVersion: 4.0.7333.3
ProductInfo.InstallState: Unknown
SystemInfo.MachineName: DC01
SystemInfo.OSVersion: 5.2.3790.131072
SystemInfo.ServicePackVersion: 2.0
UserInfo.AccountName: administrator
UserInfo.DomainName: ....................
17:35:44| Info| Property(S): GPTSupport = 1
17:35:44| Info| Property(S): OLEAdvtSupport = 1
17:35:44| Info| Property(S): ShellAdvtSupport = 1
17:35:44| Info| Property(S): Intel = 6
17:35:44| Info| Property(S): PhysicalMemory = 3326
17:35:44| Info| Property(S): VirtualMemory = 2365
17:35:44| Info| Property(S): LogonUser = administrator
17:35:44| Info| Property(S): UserSID = S-1-5-21-1709532057-437281740-2141916652-500
17:35:44| Info| Property(S): UserLanguageID = 1037
17:35:44| Info| Property(S): ComputerName = DC01
17:35:44| Info| Property(S): SystemLanguageID = 1037
17:35:44| Info| Property(S): ScreenX = 1024
17:35:44| Info| Property(S): ScreenY = 768
17:35:44| Info| Property(S): CaptionHeight = 19
17:35:44| Info| Property(S): BorderTop = 1
17:35:44| Info| Property(S): BorderSide = 1
17:35:44| Info| Property(S): TextHeight = 16
17:35:44| Info| Property(S): ColorBits = 32
17:35:44| Info| Property(S): TTCSupport = 1
17:35:44| Info| Property(S): Time = 17:35:44
17:35:44| Info| Property(S): Date = 15/02/2009
17:35:44| Info| Property(S): MsiNetAssemblySupport = 2.0.50727.3053
17:35:44| Info| Property(S): MsiWin32AssemblySupport = 5.2.3790.3959
17:35:44| Info| Property(S): RedirectedDllSupport = 2
17:35:44| Info| Property(S): Privileged = 1
17:35:44| Info| Property(S): USERNAME = .......
17:35:44| Info| Property(S): COMPANYNAME = .......
17:35:44| Info| Property(S): DATABASE = C:\WINDOWS\Installer\12893b56.msi
17:35:44| Info| Property(S): OriginalDatabase = Z:\Exchange\i386\Exchange.msi
17:35:44| Info| Property(S): UILevel = 2
17:35:44| Info| Property(S): Preselected = 1
17:35:44| Info| Property(S): ACTION = INSTALL
17:35:44| Info| Property(S): ROOTDRIVE = D:\
17:35:44| Info| Property(S): CostingComplete = 1
17:35:44| Info| Property(S): OutOfDiskSpace = 0
17:35:44| Info| Property(S): OutOfNoRbDiskSpace = 0
17:35:44| Info| Property(S): PrimaryVolumeSpaceAvailable = 19245976
17:35:44| Info| Property(S): PrimaryVolumeSpaceRequired = 53832
17:35:44| Info| Property(S): PrimaryVolumeSpaceRemaining = 19192144
17:35:44| Info| Property(S): PrimaryVolumePath = C:
17:35:44| Info| Property(S): SOURCEDIR = Z:\Exchange\i386\
17:35:44| Info| Property(S): SourcedirProduct = {FB14ED24-64E2-415E-B010-BA58590EA002}
17:35:44| Info| Property(S): ProductToBeRegistered = 1
17:35:44| Info| === Logging stopped: 15/02/2009 17:35:44 ===
17:35:44|Verbose| Method exit: Microsoft.Crm.Setup.Exchange.ExchangeMsiInstaller.Install
17:35:44| Info| Executing Install action: Microsoft.Crm.Setup.Exchange.InstallServiceAction
17:35:50| Error| System.Exception: Action Microsoft.Crm.Setup.Exchange.InstallServiceAction failed. ---> System.FormatException: Input string was not in a correct format.
--- End of inner exception stack trace ---, Error, AbortRetryIgnore, Option1
17:49:54| Info| InputResult: Abort
17:49:54| Error| System.Exception: Action Microsoft.Crm.Setup.Exchange.InstallServiceAction failed. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.Crm.Setup.Exchange.ExchangeSetup.InternalMain(String[] args), Error, OK, Option1
17:52:45| Info| InputResult: OK
Кто может , что посоветоват по этому логу?
Спасибо.
Последний раз редактировалось Kosta100; 17.02.2009 в 10:27.
Старый 22.02.2009, 14:00   #2
Kosta100 is offline
Kosta100
В продолжение темы ...
В продолжение темы по Email Router....
Миниатюры
ID:	4355   Нажмите на изображение для увеличения
Изображения
Последний раз редактировалось Kosta100; 22.02.2009 в 15:19.
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM E-mail Router Blog bot Dynamics CRM: Blogs 0 09.01.2009 06:03
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM, Email correlation and smart matching Blog bot Dynamics CRM: Blogs 0 12.11.2008 04:08
Установка CRM-3.0 Email Router на Excange2007 pkost Dynamics CRM: Администрирование 7 28.02.2008 17:36
Часовой пояс GMT +3, время: 08:25.
