Старый 25.12.2008, 15:05   #1
mscrm4ever: Expediting Plug-In Development Using VS Pre/Post Build Events
Источник: http://mscrm4ever.blogspot.com/2008/...-using-vs.html
No doubt, CRM 4.0s new plug-in engine is a giant leap compared to the callout facility that was available on the 3.0 version.
However, a few things still hinder the development process. One of which is the fact that you need to reset the Internet information services (IIS) and copy your project files to the assembly bin folder each time you compile your code.
In order to overcome and automate the process you can add Pre and/or Post Build events to you plug-in project.
Build event are no more then command line instructions you need to run before and/or after you project builds.
The nice thing about Post events is that you can set them to run only if the build is successful. Which means the iisreset won’t run and the files won’t be copied unless the build is complete. Following are the Post build command instruction I add to every plug-in project we build.
1.Open the Build Events Property Page: The Build events are located on the Project Properties page under the build events Tab.
2.Add the following commands to the Post Build Event (make sure you run the command only on successful build)
Resets Internet information Services
call iisreset
Copy the *.dll file to the assembly bin folder.
xcopy "$(TargetPath)" "C:\[CRM INSTALL FOLDER]\Server\bin\assembly" /i /d /y
Copy the *.pdb file to the assembly bin folder
xcopy "$(TargetDir)$(TargetName).pdb" "C:\[CRM INSTALL FOLDER]\Server\bin\assembly" /i /d /y
That’s it.
mscrm4ever: CRM 4.0 Concatenating Fields Plug-In Blog bot Dynamics CRM: Blogs 0 14.02.2009 14:05
mscrm4ever: CRM 4.0 Creating Interactive Plug-ins Blog bot Dynamics CRM: Blogs 0 21.01.2009 10:05
Microsoft Dynamics CRM Team Blog: Member, Static variable and Thread safety in Plug-in for CRM 4.0 Blog bot Dynamics CRM: Blogs 0 19.11.2008 00:05
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Plug-in Template for Visual Studio Blog bot Dynamics CRM: Blogs 0 27.10.2008 23:05
Microsoft Dynamics CRM Team Blog: Accessing a SQL Database from a Microsoft Dynamics CRM Plug-in Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 06:06.
