Старый 02.12.2008, 10:21   #1
Maxoon is offline
Maxoon
Не работает модуль отчетов
Сейчас стоит CRM 4.0, видимо после перехода с 3 на 4-ку перестал работать report server.
Все возможные вариации типа переставить SQL, ReportServer, Repair CRM не помогают. CRM, SQL, ReportServer стоят на одном сервере.
В логах такие ошибки...
Event Type: Error
Event Source: MSCRMReporting
Event Category: None
Event ID: 19968
Date: 01.12.2008
Time: 18:31:16
User: N/A
Computer: VRT-AS-MSK-02
Description:
Web service request ListExtensions to Report Server http://vrt-as-msk-02/reportserver/Re...rvice2005.asmx failed. Error: Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'.
The request failed with the error message:
<html>
<head>
<title>
SQL Server Reporting Services
</title><meta name="Generator" content="Microsoft SQL Server Reporting Services 9.00.3042.00" />
<meta name="HTTP Status" content="500" />
<meta name="ProductLocaleID" content="9" />
<meta name="CountryLocaleID" content="1033" />
<meta name="StackTrace" content />
<style>
BODY {FONT-FAMILY:Verdana; FONT-WEIGHT:normal; FONT-SIZE: 8pt; COLOR:black}
H1 {FONT-FAMILY:Verdana; FONT-WEIGHT:700; FONT-SIZE:15pt}
LI {FONT-FAMILY:Verdana; FONT-WEIGHT:normal; FONT-SIZE:8pt; DISPLAY:inline}
.ProductInfo {FONT-FAMILY:Verdana; FONT-WEIGHT:bold; FONT-SIZE: 8pt; COLOR:gray}
A:link {FONT-SIZE: 8pt; FONT-FAMILY:Verdana; COLOR:#3366CC; TEXT-DECORATION:none}
A:hover {FONT-SIZE: 8pt; FONT-FAMILY:Verdana; COLOR:#FF3300; TEXT-DECORATION:underline}
A:visited {FONT-SIZE: 8pt; FONT-FAMILY:Verdana; COLOR:#3366CC; TEXT-DECORATION:none}
A:visited:hover {FONT-SIZE: 8pt; FONT-FAMILY:Verdana; color:#FF3300; TEXT-DECORATION:underline}
</style>
</head><body bgcolor="white">
<h1>
Reporting Services Error<hr width="100%" size="1" color="silver" />
</h1><ul>
<li>An internal error occurred on the report server. See the error log for more details. (rsInternalError) <a href="http://go.microsoft.com/fwlink/?Link...r=9.00.3042.00" target="_blank">Get Online Help</a></li><ul>
<li>Не удалось найти хранимую процедуру "GetOneConfigurationInfo".</li>
</ul>
</ul><hr width="100%" size="1" color="silver" /><span class="ProductInfo">SQL Server Reporting Services</span>
</body>
</html>
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
и такая
Event Type: Error
Event Source: Report Server Windows Service (MSSQLSERVER)
Event Category: Запуск/завершение
Event ID: 117
Date: 02.12.2008
Time: 0:05:48
User: N/A
Description:
Некорректная версия базы данных сервера отчетов.
В голове пока каша, запутался чутка уже..
Может натолкнет кто-нибудь куда копать?
Старый 02.12.2008, 10:47   #2
AndreyS is offline
AndreyS
283 / 61 (3) ++++
Какой SQL? С какой редакции на какую переходили? Работает ли сам SRS? Что пишут логи IIS?
Старый 02.12.2008, 10:51   #3
Сабитов Андрей is offline
Сабитов Андрей
MCTS
Аватар для Сабитов Андрей
851 / 122 (6) +++++
Microsoft Dynamics CRM 4.0 Connector for SQL Reporting Services
The Microsoft Dynamics CRM 4.0 Connector for Microsoft SQL Server Reporting Services is a service that connects the Microsoft Dynamics CRM Server computer to the Microsoft SQL Report Server computer. The Microsoft Dynamics CRM 4.0 Connector for SQL Reporting Services eliminates the Kerberos double-hop authentication that was required for Microsoft Dynamics CRM 3.0 deployments when SQL Server Reporting Services was installed on a separate computer.
Старый 02.12.2008, 10:53   #4
AndreyS is offline
AndreyS
283 / 61 (3) ++++
Андрюха, все стоит на одном сервере
Старый 02.12.2008, 10:54   #5
Сабитов Андрей
MCTS
851 / 122 (6) +++++
Упс, сорри за не внимательность :-)
Старый 02.12.2008, 11:27   #6
"Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'." Скорее всего что-то с сайтом RS и вместо страницы Report Manager (http://vrt-as-msk-02/reportserver/Reports) выдается страница с сообщением ошибки. Посмотрите все ли в порядке в средстве Reporting Services Configuration, а так же просто постарайтесь пробиться браузером на обе страницы службы отчетов.
Старый 02.12.2008, 11:28   #7
Maxoon is offline
Maxoon
sql 2005,
report server не работает. При попытке обратиться http://server/reportsever выдается следующее
An internal error occurred on the report server. See the error log for more details. (rsInternalError) Get Online Help
в логе iis такая ошибка, больше нет ничего вроде бы
2008-12-02 08:17:53 W3SVC1 192.168.1.168 GET /Company/_common/error/errorhandler.aspx ErrorCode=0x80048300&RequestUri=%2fCompany%2fCRMReports%2frsviewer%2freportviewer.aspx&BackUri=http%3a%2f%2fvrt-as-msk-02%2fcompany%2fcrmreports%2fviewer%2fviewer.aspx%3fid%3d%7b3626150B-62A0-4228-9411-DE16AD917573%7d%26helpID%3dAccount%2520Distribution.rdl%26action%3dfilter 80 - 192.168.1.168 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+5.2;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.04506.30;+.NET+CLR+3.0.04506.648) 401 1 0
2008-12-02 08:17:53 W3SVC1 192.168.1.168 GET /Company/_common/error/errorhandler.aspx ErrorCode=0x80048300&RequestUri=%2fCompany%2fCRMReports%2frsviewer%2freportviewer.aspx&BackUri=http%3a%2f%2fvrt-as-msk-02%2fCompany%2fcrmreports%2fviewer%2fviewer.aspx%3fid%3d%7b3626150B-62A0-4228-9411-DE16AD917573%7d%26helpID%3dAccount%2520Distribution.rdl%26action%3dfilter 80 Domain\user 192.168.1.168 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+5.2;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.04506.30;+.NET+CLR+3.0.04506.648) 200 0 0
Редакция SQL не менялась вроде бы...
Старый 02.12.2008, 11:33   #8
Хотя нет, прошу, прощения за невнимательность. Ругается на отсутствие процедуры GetOneConfigurationInfo. Может быть тогда стоит убить базу отчетов и создать ее заново?
Старый 02.12.2008, 11:58   #9
AndreyS is offline
AndreyS
283 / 61 (3) ++++
Хорошо, что редакция SQL не менялась. Вопрос был: "Какой SQL?"
Старый 02.12.2008, 12:17   #10
Maxoon is offline
Maxoon
SQL 2005
Вобщем убил базу, директории в iis, в report config manager-е заново все создал и настроил.
Сам сервер теперь вроде работает, на запрос http://server/reportserver выдает
server/ReportServer - /
Версия 9.00.3042.00 служб Microsoft SQL Server Reporting Services
После сделал repair crm-а, но отчеты не формируются
reporting eror
The report cannot be dispayed...
в логах
Event Type: Error
Event ID: 19969
Date: 02.12.2008
Time: 12:15:53
User: N/A
Description:
Web service request SetParameters to Report Server http://vrt-as-msk-02/reportserver failed with SoapException. Error: Невозможно найти элемент "/company_MSCRM/4.0/{BA6599F5-9751-DD11-81C0-000C29F1EC99}". (rsItemNotFound)
Как-будто нету отчетов....
Старый 02.12.2008, 12:36   #11
Посмотрите какая структура каталогов была создана на Report Server после процедуры Repair? Возможно стоит убить все отчеты из 3.0 вместе с соответствующей категорией, после чего переустановить (а не чинить!) сервер. Может быть в этом случае не будут создаваться лишние директории и все заработает.
Старый 02.12.2008, 15:02   #12
Maxoon is offline
Maxoon
прошу прощения, а как и где посмотреть структуру каталогов? и как удалить отчеты?
Старый 02.12.2008, 15:21   #13
Ну, например по ссылке http://server/reportserver которую вы приводили. CRM должна была создать на сервере каталоги в которые публикуются отчеты перед запуском. В ошибке говорится, что что-то с ними не так.
Вообще говоря, обычно создается 1 каталог с названием организации и все. В случае когда сервер обновляется, кажется, создаются дополнительные папки с отчетами версии 3.0 и 4.0. Кажется сбой где-то тут. К сожалению, виртуалка с обновленной системой сдохла и я не могу с точностью это утверждать.
Старый 02.12.2008, 15:26   #14
AndreyS is offline
AndreyS
283 / 61 (3) ++++
Или через Report Manager http://server/reports (только надо выбрать пункт "Показать подробности")
Старый 02.12.2008, 15:32   #15
Maxoon is offline
Maxoon
У меня там как ни странно - пусто!
а в самом crm-е отчеты есть, только задублированы после обновления...
см скриншоты
Миниатюры
ID:	4014   Нажмите на изображение для увеличения
Старый 02.12.2008, 15:37   #16
AndreyS is offline
AndreyS
283 / 61 (3) ++++
Боюсь, что Вам поможет reinstall
Скорее всего, проблема с RS возникла во время обновления. Т.к. отчеты - это еще и объекты в CRM, то они отображаются в самом CRM, но физически на RS их нет.
Старый 02.12.2008, 15:55   #17
Согласен, очень странно. Посмотрите нет ли у вас категории CRM 3.0 Reports? Если есть, то я бы удалил все отчеты в этой категории, потом саму категорию, а потом и сам CRM сервер. После чего попробовал заново его установить.
Старый 02.12.2008, 16:01   #18
Maxoon is offline
Maxoon
а где посмотреть категории CRM 3.0 Reports???
простой ре-инстал мне тоже не помогает ((((
Последний раз редактировалось Maxoon; 02.12.2008 в 16:33.
Старый 02.12.2008, 16:47   #19
Maxoon is offline
Maxoon
Парни, ура!!!
проблема известная, вот тут решение
http://www.eggheadcafe.com/software/...when-open.aspx
Мне помогла утилита
C:\Program Files\Microsoft Dynamics CRM\Tools\PublishReports.exe
Всем большое спасибо!
За это сообщение автора поблагодарили: Артем Enot Грунин (4).
Старый 02.03.2009, 13:06   #20
Meroniuss is offline
Meroniuss
Скажите пожалуйста, где мжно скачать Microsoft Dynamics CRM 4.0 Connector for SQL Reporting Services?
reporting services
Не работает переключение языков a33ik Dynamics CRM: Администрирование 11 23.12.2008 11:05
формирование отчетов Lud Dynamics CRM: Разработка 6 04.07.2007 12:31
Настройки категории в списки отчетов с помощью ISV.config austri Dynamics CRM: Разработка 1 04.06.2007 06:25
CRM Deployment Manager. User manager не работает kras Dynamics CRM: Администрирование 18 05.12.2006 17:34
CRM очень медленно работает... CRM30 Dynamics CRM: Администрирование 12 26.07.2006 18:01
Часовой пояс GMT +3, время: 13:36.
