Старый 28.04.2008, 13:05   #1
Arijit Basu: AX .NET BC - Sample Project [Level 100]
Источник: http://daxguy.blogspot.com/2008/04/a...level-100.html
Hi, I've created a small sample project which demonstrates the use of .NET Business Connector . Ive created a Windows Application which uses the .NET BC to interact with AX. Its useful for beginners who want to understand the .NET BC. This sample shows how to read data, invoke class & table methods, insert records into AX. I've made the source files [VS 2005 Project & the AX Class ] available so you can play around with it. To use this project, you need to have access to AX, have the .NET BC installed & configured, the current windows user must have access to AX. You also need to import a sample class into AX to make this work. All files have been shared. Any improvement suggestions would be greatly appreciated.
Let me know if you face any issues.
The Application (AXBusinessConnector.exe) looks like this :)
The Source files are uploaded below:
Happy DAXING :)
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
Arijit Basu: Using AX .NET BC to create Purchase Orders Blog bot DAX Blogs 0 14.06.2008 14:10
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Часовой пояс GMT +3, время: 07:04.
